Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 95
Thread: brake caliper swaps for 83-85 200x's
  1. #31
    Apr 2008
    Biloxi, MS
    149
    read through this and have been looking on ebay. i'm looking at replacing the front and rear brakes on my 200x that i'm building. unless i read wrong, i need a cr80 front caliper for the rear brakes on the 200x and i need a rear kx80 or kx85 caliper for the front of the 200x. other than new brake lines, do i need to replace anything else? can i still use the 200x cylinders or do i need to swap them out as well?
  2. #32
    PA
    3,515
    the master cly will be ok but the newer front master cly work better
    WWW.HREATV.COM
  3. #33
    The Open Road
    4,727
    I agree with Swigin....the parts will work together but imagine this for a moment
    yer out 300 miles from the house riding trails with a group of buds when you blow a seal on the only old part left of your brake system...there`s a cycle shop in town 20 miles away from the trails but they only have newer dirt bike stuff on the shelf...and you are left wishing you had put a CR85 master on yer ride
    keep in mind that I just got this swap done on one of my trikes....but when you mount your X mounting plates to these new calipers, I would suggest using the newer posts/studs on your mounting bracket...the newer studs are grooved to retain grease on the big stud ( the allen head stud)....the brackets for the KX and CR calipers came with them when I bought them so I took them apart and compared them...the newer studs are WAY BETTER
    I have a pile of 3 or 4 old X calipers....funny thing is they were locked up NOT because the puck was siezed in the caliper pot, but because those mounting studs were never serviced or lubed and it was the big stud the caliper slides laterally on that was stuck tight and locking up the caliper on EVERY one
    the calipers would have been salvageable had they been lubed once in awhile...which seems to be oft overlooked when servicing your machine
    you fellas with old trike calipers that sill work should look into at least updating those studs and/or lube-ing your old one REGULARLY....newer style has a steel sleeve inside the slider hole so it`s steel on steel...the older Honda units have a steel stud sliding in a bare aluminum hole which is prone to shrink up and sieze...it is possible to press out a siezed stud out of the caliper, however in some cases it will destroy that aluminum bore making for a sloppy fit and greater chance of dirt to get inside and create more damage
    I did Jason`s swap and he is correct.....as long as you use the X mounting plates, they bolt right the heck up with no issues whatsoever
  4. #34
    Apr 2008
    Biloxi, MS
    149
    well, i am the new owner of kx85 rear brake assembly and cr85 front brake assembly. both include the master cylinders. anything else that i'll need for this swap other than new pads and probably new brake lines?
  5. #35
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by n10sivern View Post
    you can just reuse your original brake lines/hoses the ends were they attach to the caliper are the same. the kx and cr pads are exactly the same as the 200x caliper used. So if you already bought 200x pads they will fit no problem
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  6. #36
    Apr 2008
    Biloxi, MS
    149
    sweet, cant wait on them to get in even though i can't even install them for about another month until i get my frame stripped and painted.
  7. #37
    adamd's Avatar
    adamd is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    west ky lbl
    269
    ok just to check and make sure does the 05 cr85 front caliper fit the 200x?
    3 wheelers
    1983 200x flat tracker
    1983 200x almost original
    1983 200e bigred parting out
    let me know what parts you need
  8. #38
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by adamd View Post
    yes it will work perfectly.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  9. #39
    Sep 2003
    Elizabethtown PA
    1,581
    back to the top for more people to notice it and help them out.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  10. #40
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by jason85atc250r View Post
    same as above.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  11. #41
    Jun 2004
    Pyeongtaek, South Korea
    474
    Thanks for the insight and clarification, y'all! I saved every pic and made plenty of notes for my 200X build. I'll get to it eventually. The good news is that my son is only five months old, so I have plenty of time.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
  12. #42
    Nov 2007
    Bringing this back up.
    I just installed a cr 85 1998 year front caliper on the rear of my 84 200x.
    All is needed is to swap the mount of the cr 80/85 with the original off the 200x caliper.
    thanks for the research jason
  13. #43
    Jun 2009
    Ventura, Ca
    22
    I just put an 03 CR85 rear caliper on my 85 350x. Works perfect! Thank you for the idea Jason85atc250R
    83 250r
  14. #44
    OH
    87
    will this work on the 86 350x? i know the 85 and 86 rear calipers mount differently. If someone could tell me calipers that will bolt on the 86 350x id appreciate it. Only calipers i have laying around were z400 fronts the mounting holes actually line right up w/ rear brake stay holes, but the brake line and banjo wont let it sit right when you try and mount it on the bike.
  15. #45
    Sep 2003
    Elizabethtown PA
    1,581
    To do this swap you have to reuse the caliper mounting bracket and just cwap the CR caliper over to it. It'll work on your 86 350x
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
