Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 61 to 75 of 95
Thread: brake caliper swaps for 83-85 200x's
  1. #61
    pcs's Avatar
    pcs is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2011
    yuma, az
    465
    added info, i swapped out my rear caliper with had new pads and the were the same as the 2000 cr 80, the cr bracket did not work and when i put the cr caliper on the 200x bracket it bolted up but the small notch on the bracket would rub with the cr caliper, then i swapped back the 200x caliper and it would not??? i ended up just shimming the bracket withe cr caliper to give the notch some clearance and it works well now.
    Team Blue: 85 Tri-z 250: under the knife
    Team Red: 87 Trx250r 01Cr80 15 CBR600RR
    Team Yellow: 06 Ltr450 11 Hayabusa
  2. #62
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    I will be putting a cr80 caliper at the back and using the cr handle master. I'll just get a longer brake hose to reach the back.
    I'm worried about the fitting I would need to have to make my hose fit on the master cylinder... Like this one: http://www.ebay.com/itm/180843788998...84.m1438.l2649
    The fitting on the master doesnt look like a banjo? Can I replace this fitting with a banjo?
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
  3. #63
    OK
    5,450
    Quote Originally Posted by ailll1 View Post
    Looking at pictures I would say no, you can't put a banjo fitiing on that master. I would think you could get a hose made with the right fitting though.
    It would be easier in the long run to get one with a banjo fitting on it already.. It may cost you more but in the long run it will probably be in better condition anyways. I used a 2003 CR85 caliper on mine.. It was fairly cheap, looked new and had new pads in it too..
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
  4. #64
    ailll1's Avatar
    Dec 2009
    Québec
    405
    Thanks! I bought a 05 cr85 complete front brake system 2 days ago. As I didnt get any response, I assumed it wouldn't have fit so I bought one with a banjo on it. The dude said he'll throw in a good set of padsalong with it.
    I just need to figure out what lenght I'll need to reach the back...
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
  5. #65
    Sep 2007
    100mi west of Chicago
    3,582
    I'm running a CR85 front caliper, rear master, and rear brake hose for the rear brakes on my 200x. The line could be an inch or two longer but it does the job. I emailed a bunch of sellers on eBay asking the lengths before I bought
    Rob
  6. #66
    ailll1's Avatar
    Dec 2009
    Québec
    405
    The problem is that I dont have any of the 200x rear pedal and linkage... That's why I'd use the front master to operate the rear brakes. I wouldn't get much braking up front with a front max tire anyways.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
  7. #67
    Sep 2007
    3,582
    I guess I didn't read your post close enough to understand what you are doing lol.
    Rob
  8. #68
    ^ Apparently he doesn't want to buy the foot brake parts and uses the front master cylinder and a long azz line to the rear caliper cable.
  9. #69
    Manheim, PA
    5,816
    I wanted to add some info to this I found out last night on the 200X brakes.
    83-87 atc200x use the same front calipers
    83-87 atc200x use the same rear calipers
    81-84 atc250r use the same front calipers as 83-87 atc200x
    82-84 atc250r use the same rear calipers as 83-87 atc200x
    the rebuild kits and brake pads are the same for both of these models.
    in edition ive learned this too:
    the following quads front calipers use the same brake pads and rebuild kit....so my guess is we can swap calipers also (would need right sides if this works)
    87-92 trx250x
    93-current 300ex
    99-current 400ex
    And on top of all of this information I know for a 100% sure fact 04-05 YFZ450 swap directly onto the 250x/300ex/400ex so after a little bit of work I am going to see if i can use a YFZ450 right caliper onto the 83-87 200x and 83-84 250r
    Keep yall updated.
  10. #70
    Scootertrash's Avatar
    In the sticks
    4,638
    Thanks for updating this oldskool, I'll be doing a couple conversions this summer (hopefully). Please keep this updated. Thanks again!
  11. #71
    Manheim, PA
    5,816
    Update, YFZ450 calipers will not work, nothing bolts up and banjo bolt is on the side also. However in my search for newschool on oldskool I can add some info.
    KLX140 and KLX140L rear caliper are the same as all kx85/kx100. This opens up the world of calipers a little more.
    enjoy.
  12. #72
    Apr 2012
    USA
    4,133
    I started researching these (indepently from your results) and came across a cross brand reference into yamaha .
    I have not dug deep on the yamaha side yet, but here is the brake pad set that should be exactly the same as the 200x, but in the yamaha world, have not touched on the calipers etc really.
    http://www.sixity.com/2004-2011-yama...ront-rear.html
    EDIT!
    I stumbled onto a list of 100% interchanges, but they dont say front vs back, but one or the other WILL fit, so I guess look at photos and compair before buying . I'll work on verifying front vs rear vs both in time.
    I think this list only included ATVs, since we already know some motor cycles fit and this list has none.
    • 83-87 atc200x
    • 82-84 atc250r
    • 85-86 atc350x
    • 87-92 trx250x
    • 93-04 trx300ex FourTrax
    • 06-08 trx300ex
    • 01-06 trx300ex Sportrax
    • 2009 trx300x
    • 06-08 trx400ex
    • 99-00 trx400ex FourTrax
    • 01-06 trx400ex Sportrax
    • 2009 trx400x
    • 08-09 YFM250R Raptor
    • 95-05 YFM350FX Wolverine 4x4
    • 05-06 YFM350RSE Raptor Special Edition
    • 87-04 YFM350X Warrior
    • 01-05 YFM660R Raptor
    • 02-05 YFM660RLE Raptor Limited Edition
    • 03-06 YFS200 Blaster
    • 2006 YFS200SE Blaster Special Edition
    • 87-06 YFZ350 Banshee
    • 03-05 YFZ350LE Banshee Limited Edition
    • 05-06 YFZ350SE Banshee Special Edition
    • 2000 YFZ350SP Banshee 50th Anniversary Edition
    • 04-05 YFZ450
  13. #73
    Manheim, PA
    5,816
    its said warior and banshe front calipers are the same but i dont want them, they are pretty much equaly as old.
  14. #74
    Apr 2012
    USA
    4,133
    Seems like banshee rear calipers are still made, the old 3 wheeler ones are NOT made any more. Here is a quick result I found for New and basically unlimited stock of rear calipers. I couldn't even find a new old stock 200x caliper to compare prices. The machines might be old, but parts are new and more available than the old hondas.
    http://www.ebay.com/itm/New-OEM-rear...-/330513599520
  15. #75
    Manheim, PA
    5,816
    eastcoat atv sells new rear 200x calipers which are the same as 2nd gen 250R calipers. Id rather have KX and CR calipers if needed. I put a 2012 TRX450R rear caliper on my 200x, its not a bolt on. talk about grabbing power.
