Results 1 to 8 of 8
Thread: Need help finding a piston
    Greiver430x's Avatar
    Greiver430x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Swiftwater, Pennsylvania, United States
    444
    Ok, parts for my 350x motor are long overdue. Apparently the dude at the machine shop said it would be a waste to resleeve my cylinder and get a new piston because there is so much material left on it. So the guy at the shop said he got a lead on a 20 thousanths oversize for it. Problem is he hasnt said anything else about it, Its been like almost three months and i wanna finish my quad so hereis what im looking for if any of yall can give me some info. I have a powroll big bore and stroke kit, the piston is 86 mm, and im trying to find an oversize for it. Please help me if you can, its startin to get nice out and im starting to get an itch to ride.
    2 1978 Yamaha xs750 specials
    2008 Kawasaki KFX450R
    Powermadd handgaurds, K&N, UM Full skidplate,Dg nerfbars with heelguard and pegs.Maxxi RAZR's all around MORE TO COME.
    1987 Suzuki 230 Quadsport, all stock and one mosquito fighting machine
    Black Booger Crew member
    florida
    2,328
    i know put the motor back in the trike where it belongs...Then call powroll......
    Billy Golightly's Avatar
    Live Oak, FL
    15,067
    Well, you should have a couple options. First you can contact powroll directly and see if they have an oversize piston kit for their big bore sleeve. They should, but if they do not then...
    You need to take a good hard, long look at the Wiseco off-road catalog http://www.wiseco.com/default.aspx I just browsed through mine I have saved and found the XR350 engine is 84mm std, and the xr400 is 85.0mm Theres liable to be other brands in the same bore range also, just be wary of wrist pin location varying between different engines.
    444
    Yeah guess ill have to get in contact with powroll, and im working on getting a decent 350x to put the powroll motor not sure if want to do it though because the 250x frame is set up for flat trackin already.
    PA
    3,515
    i know a early 80s xr500 piston will work and its a 89mm
    and with a 4mm stroke that will be a 460
    now what i dont know is what stroker you have and with a xr500 piston the rod needs to be shorter then normal ....id say call powroll
    ps....if i remeber right the xr500 piston pin is 3mm lower then a 350x piston...thats why the rod needs to be shrunk more them normal
    WWW.HREATV.COM
    444
    I have a 6mm stroker crank in it, would a 400 ex piston work they have them in 87mm in the weisco cataloge
    PA
    3,515
    sorry i was wrong, i meant 6mm
    heres a handy chart http://www.3wheeler.org/vb/archive/i...p/t-15209.html
    WWW.HREATV.COM
    444
    Well im going to bid on a stock cylinder and piston on e-bay that seem to be in good shape that will get my ride up and going untill i get my other parts.
