Well I received my newly sleeved cylinder from LA Sleeve this afternoon. Extremely disappointed would be an understatement. The last time I had called them they informed me that they would have to charge an additional $175 to match the new sleeve to my existing porting. After a few questions I was told that original port matching was included in the cost of sleeving it. I did very very little work to the transfer outlets, most of the time was spent on the exhaust, intake, and transfer tunnels. So I had decided I could match those areas up again as they were for the most part pretty east to reach and get to with the tools I had.
I received the cylinder today and found the intake almost completely blocked off, the transfer outlets on the sleeve are about 1/4 inch higher then the casting so now they are pointed upwards at an angle instead of straight across like they are suppose to be. The exhaust for the most part they did pretty decently, I'll have to re-grind the sleeve to match what I had but its the least worse out of whats there. The Transfer tunnel opening from the bottom is almost COMPLETELY closed off because of the bottom shape of the sleeve, its absolutely ridiculous. I had tons, an tons, and tons of hours into this cylinder before hand and I've easily got twice that from the looks of it to get this thing where its even usable. I don't have an effin clue how I'm going to reach around in the transfers and fix them unless I just end up raising the height of all of the ports to match it which is going to lessen my blow down time (Generally not a good thing for a high rpm-power engine).
Looks like I might be at TF for the 3rd year in a row on a stock cylinder...I'll try and get some pictures of it posted this evening. Man
