Thread: need help from you gearheads!!
    Feb 2007
    honolulu hawaii
    64
    Question need help from you gearheads!!
    ive asked before but i never got a answer, i ride a shaft drive klt 185 it is geared way too low, how if possible can i change the gear ratio? taller tires arent a option.
    Sep 2005
    central Illinois
    651
    the only thing i could think of is get into the case and change some gears or change the rear axle gears (probably best option) if they are even available. But I've never gotten into a shaft drive system before so I dunno, just trying to throw some ideas to ya! I would assume that if there are gears in the axle to change, than it would be like swapping sprockets
    Feb 2007
    honolulu hawaii
    64
    yeah i appreciate it i just dont know where to find a different ratio. maybe one of the newer models has compatible parts, i gotta do something!!
    Apr 2006
    Rushford MN
    141
    Don't bother, for what you will gain on top end, figure double that lost on the bottom. If its that bad, make your motor rev more, or step the tires up some. I have taken auto rear ends apart and they can be a PITA, so I am sure a atv one would be a lot worse.
    tecate kid
    Feb 2007
    honolulu hawaii
    64
    damn, i could lose alot of bottom though!! ill keep it as is i guess. it just sucks that i beat everybody till i top out at 43 and then the bigger bores pass me then!!
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by dirt bike dan View Post
    Make 'em follow you around some corners...
    2-stroke lover
