Does anyone out there know someone who can machine a set of custom triple clamps?
I know quite a few locals that can do it.........pm me I'll send you my number
What forks are you trying to use? I put a stock 350X front end on my 600X by modifying the XR600 stem and pressing it into the 350X lower triple. I just had to weld up some material on the outside of the bottom of the 600 stem and then turn it back down to the right size on a lathe (allowing for a press fit of course). I met a guy who had a CR500 trike and his triples looked like way to much work, I'm sure he could've done the same thing that I did in a lot less time for a lot less money (it was free for me since I did all the work). If you're really dead set on making a set of triples I could probably make some...
Thanks,
-J
