Originally Posted by
honda250sx
Hopefully DirtCrasher will chime in on this one. He's the man when it comes to ES/SX rearend builds. I have done two. I have used an AllBalls bearing and seal kit both times and i have always had a good axle. Be sure to seal everything up nice and tight. And be sure to run a bead of silicone on the NEW drive shaft boot that you should get as well before clamping up on swinger. Also make sure not to mix up shims on either side of the gear. These are in there to make the gears mesh properly. As for the pins i just have generic kit you can get from just about anywhere. Matched up and installed. Trim to size if need be.
