Results 1 to 14 of 14
Thread: tire hot patch removal??
    Front royal, va
    2,186
    how did you remove the lettering on the side wall??
    carb cleaner wont even smear it !
    Ontario, CANADA
    4,538
    Hey Nathan, I asked this a long time ago to try and get my RAZR sticker off. No such luck! Tried it all
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Jan 2005
    Jones, Michigan
    1,821
    its just a guess and it might make it look rough but how about a wire wheel or an SOS pad?
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    Wire wheel is the most common method. Some track guys do that to keep their compounds secret
    Jan 2005
    Jones, Michigan
    1,821
    wooohoooo i was right about something for once
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    Front royal, va
    2,186
    thanks ya'll!
    i was waiting for some smart@ass to say "paint over it or something"
    Live Oak, FL
    15,070
    You could maybe use a big wood file too if you wanted a little bit more control over the damage done? Just another thought.
    Cincinnati, OH
    3,289
    i have seen people use a putty knife that has been heated up. when you coming to get your R?
    Sep 2003
    El Paso Tx
    1,123
    ok, doesn't anyone have a compressor? How about an air sander or grinder to make short work of such things? ....Or you can paint over it.
    So many idiots that can't ride a motorcycle, so few hours to put my boot in their seat!
    Myeh heh heh heh heh!!!
    Northern CA
    1,104
    Just use the EASY OFF Oven Cleaner....
    Stick it in for 4 hrs at 450 Degrees.....Make sure you spray some of that BBQ Pam on the rack though...You dont want anything sticking in there...Holly would be Pissed
    85' Tri-Z 250
    85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    87 Ninja750 3wheeler
    Jan 2005
    RI
    2,530
    wont that hurt the tire?
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Northern CA
    1,104
    Nah,,,,,Most of the Tires these days are Heat Treated....Just because the ATC/ATV's are much faster causing more Friction Equaling More Heat....Desert Tires are the Best for Heat conditions....You can Cook them Longer and at Higher Temps which Acclimates them to the Rough Desert Temps...
    85' Tri-Z 250
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    Front royal, va
    2,186
    you guys are killin me
    Sep 2003
    El Paso Tx
    1,123
    Whats wrong with getting a sharpie and painting over the white anyways? Its so much easier than going out and investing in a tool that you don't really use? Here's a better idea: Go to a tire shop that does retreads and pay them to slice them off. Or again, you can just paint over them and be done with it and go ride instead of creating a Rube Goldberg machine.
