Results 1 to 7 of 7
Thread: Can I cut the headgasket to increase cooling capacity?
    Utah
    644
    I got a new cometic head gasket for my '85 250r.
    The cooling port cutouts on the headgasket are smaller than the port openings on the cylinder jug and head. Can i cut out the port openings on the headgasket to match the size of those on the jug. I'm thinking it would increase the coolant flow and maybe run cooler. Has anyone ever done this before?
    My only concern was that maybe the reason the holes on the gasket where so small towards the rear, was becuase thats where the inlet hose is and that maybe it would force the coolant aroud the entire jug more instead of taking the shortest path between the two hoses and only cooling half the head.
    Any input would be nice.
    Also has anyone run the cometic headgasket compared to oem? Does oem have full sized cutouts, or only partial like cometic?
    THANKS
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
    Aug 2007
    Moab, UT
    1,807
    They are the same size if I remember correctly. They do restrict flow for a reason though. If your coolant circulates too fast you could run into overheating issues.
    Aug 2004
    Phoenix
    1,229
    Leave it the way it is, Honda designed it that way for proper flow.
    Remove all the warning label and let nature take its course
    Sep 2003
    Elizabethtown PA
    1,581
    i have a O ring cool head on my trx250r and it works fine. theres no gasket so the holes are wide open. i have not had any overheating problems.
    i was thinking of doing the same thing to my 85 atc250r when i have to rebiuld it next time.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Keep it that way.
    Jan 2004
    Palmetto,Florida
    2,300
    They did that to force more flow towards the HOT Exhaust Side.. Run Leaded High Octain Gas and it will cool it some
    "07" DR650 Suzuki Dual Sport
    Utah
    644
    Thanks for the replies. That was my original thought, but I wanted some more input on it just to be safe.
    '85 200 Big WHEEL
