-I'm converting a 185s to a racer by adding a Tecate type swinger. As you know, the 185s had NO rear suspension, so I will basically be reworking the whole back half of the trike. I will be using the stock axle and carrier for now...will maybe change it later. As you know, the 185s and BRs adjusted the chain by pivoting the whole axle carrier. I will use this same setup. So if you are familiar with the earlier T3s, they still used this old setup...My swinger will look similar. I have purchased a nitrogen shock off of a yamaha crotchrocket- R6 I think. It is too stiff I know but I think I can compensate that by using extreme linkage geometry. I will be using rectangular tubing for the swingarm. I am using wristpins out of an automotive engine as bushings (about 5/8 ID). These should have optimum wear characteristics. I don't know if I can even drill them for zerks though? Another thing I have been kicking around with my shock linkage is making it adjustable. Why not put a turnbuckle in the middle of the rear connecting link? This way I can change shock height and ultimately change ride height, you know go from motocross to ice racing in a few minutes. Any way I have been putting off chopping my frame because this is my daily driver. I want to get everything figured out and then just do the project all at once. I decided I need some rear suspension after bending 2 axles, cracking a wheel and bending another. I do some way too extreme stuff for a ridgid axle trike. I'm lookin' at buyin' a Tecate but until then this will be a neat project. Any input is much appreciated! thanks.
A few questions:
-I am always bottoming out my forks. I installed heavier springs and different valving by TerryKit. What will putting synthetic Shelbourne 80w gear oil in my forks hurt? It will definately stiffen them up. I am currently running 10w-30w.
-Also I read a thread on hydroforming and am kicking around the idea of making an exhaust with a small expansion chamber (kind of like FMF powerbomb) here's link http://i.timeinc.net/mx/content/imag...rotopipesm.jpg this is an FMF prototype for 4stroke mx bikes
-Also any input on the adjustable shock linkage would be appreciated.
