Results 31 to 45 of 47
Thread: 1981 Atc250r
  1. #31
    Dec 2007
    Indiana
    235
    It was Christmas today!! Finally got my piston and stuff from ProCycle. Bunch of nice guys there. I got my 71.5mm Wiseco piston, rings, wrist pin and clips, and my complete top end gasket set for less than Wiseco wanted for the piston alone. Wiseco wanted $177 for the piston, i got all my stuff for $147 Shipped to my door in 5 business days!
    Plus i got some sweet stickers!
    now ive just got to take the piston to the machinist, and let him make sure the clearances are correct.
    - Phil
  2. #32
    Apr 2007
    Springfield, PA
    889
    nice deal on that piston kit. stickers are the best part! anything else you plan on doing to it?
    My Rides
    1983 ATC200 - U-Haul edition - great mudder - SOLD
    1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
    1987 Suzuki DR200
    199? Go-ped Sport
  3. #33
    Dec 2007
    Indiana
    235
    Well, i scored a pair of ITP Holeshots on gold aluminum EX rims for $75. I need hubs still (on the cheap). Im looking at an extended swinger for $100, as long as it will work on my trike.
    I still need to know the best way to break this thing in. I was told to ride for a full tank of 20:1 mix at no more then half throttle, varying the RPM the whole time. Anything else?
    -Phil
  4. #34
    Dec 2007
    Indiana
    235
    Well, today i planned to pick up my cylinder after he checked the clearances. I figured it would take all of 20 minutes for him to hone the cylinder to spec and so on, but no...he said he would TRY to get done by monday
    I had planned to put it together and break it in today. oh well.
    -Phil
  5. #35
    Dec 2007
    Indiana
    235
    So, i started putting the R together but ran into a problem...i cannot get the 2nd wrist pin clip in. Ive tried and tried and tried, but nothing. Is there a special way to do this? special tool or somethin?
    -Phil
  6. #36
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    Quote Originally Posted by money89tractors View Post
    I will check on the registering deal. They just passed a law here in indiana where ATVs can be registered for public road use. Secondary roads only of course.
    looks like i may move to indiana!
  7. #37
    Aug 2007
    Brookings, South Dakota
    133
    If you want to grab a couple horses while you got the motor apart I'd mill the head. I think mine is about .030 over which is also what I did to my dirt bike. 6.1:1 Is I think what they are stock which is pathetic. Besides it'll have a better Idle, you should hear mine it has that really sharp ting sound. good thing is these motors are extremely easy to work on and are easy to get more power out of, Gotta love 2-strokes.
    '81 ATC 250r: IMS tank,Uni pod filter,Keihin PJ flat 38mm,Boyesen Pro series reeds,reed spacer w/ boost bottle,milled head,bored(.080),ported,machined CR exhaust flange,and Mugen pipe.PK +3 swingarm,2+2 axle,ITP rims,and 200X fork swap w/ polished tree.
    '03 CR 250R: FMF fatty w/shorty, Pro Taper top clamp
    '85 ATC 70: 88kit, race cam, ported head, 5 angle valve job, cobra pipe, 20mm carb...
    '73 ATC 70 roller, '80 ATC 110, '86 ATC 125m, '81 XL 500s, '71 Z50, '76 Z50 W/ Lifan 125
    '84 Tecate 3
  8. #38
    Dec 2007
    Indiana
    235
    Any idea on an easy way to get these wrist pin clips in?
    -Phil
  9. #39
    Dec 2007
    Indiana
    235
    So, i got the trike together, ready to fire it off...kick it over a couple times and it fires, but wont stay running.
    Its burning the fuel, because its smoking when you kick it over, but itll over run for a couple seconds, then die. When you give it gas, it wants to die, but when you let it try to idle, its tries to keep running. I cleaned the carb, put in new reeds, what more could it be?
    -Phil
  10. #40
    Feb 2008
    Benson,NC
    56
    change the spark plug!! i went through 5 plugs after a rebuild b/c i used some 2 stroke oil as lube when i reassembled. btw- 20:1 is REALLY RICH. i use 32:1 on break-ins, then drop it 40:1. Just my 2 cents...........
    I bust-ass on 3 wheels.
  11. #41
    Aug 2005
    Portland Or
    412
    Dude I am in the exact same boat as you. Never let a four stroker fill yer bike.
    How was yer bottom end? con rod bearing and all. I caught mine before it seized and dont have nearly the cylinder damage you did, so i figure if yer bottom end is ok then I shouldnt have too much to worry about. plus my bottom end was rebuilt pretty recently.
    "Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."-Ernest Hemmingway
  12. #42
    Dec 2007
    Indiana
    235
    My bottom end is in great shape. I am going to clean the carb again, adjust the floats, and get a couple new plugs.
    I also need to pull the jug off again because it didnt seal in on corner (the area around he stud is dirty and not letting it seat completely)
    -Phil
  13. #43
    Dec 2007
    Indiana
    235
    I cleaned out the carb and adjusted the floats. It will not fire over and run for a good while, then die. It sounds like it has a lot of lag on the top end. I pulled the main jet, it has 158 stamped on it. Could this be too small of a jet for the fresh top end(71.5mm)?
    -Phil
  14. #44
    Dec 2007
    Indiana
    235
    Can anyone give me any idea at all? i Really want this going before TF!! (if its not running by then im just bringing it and hoping some of you nice fellas will help me out.).
    -Phil
  15. #45
    Dec 2007
    Indiana
    235
    Well, i found the problem. Since everyone here had so many guess's...
    The CDI box is bad, it works long enough to fire the engine and run for a minute, then it fails. I put another CDI box off an '04 Kazuma 110cc quad (cheap 4 wheeler) and it ran amazing; until the R fried that CDI box. The box was well used before i got to it, so i ordered a new one from the Kazuma company (honda's CDI boxs and made by the same company, yet the Kazuma CDI box is $10 shipped and the Honda box is close to $70 + shipping)
    -Phil
