Results 1 to 2 of 2
Thread: How to tighten 250R chain (spanner nut)
    Oct 2007
    corinth ms.
    77
    hi guys, what do I turn on the rear end of my 84 250r (westcoast swinger) to tighten the chain. Is it the big spanner nut inside the spocket? if so do i turn it up or down? thanks, Joe
    Apr 2002
    s.w. michigan
    6,498
    Yep,
    the large thing beside the sprocket.
    Be sure to loosen up the 2 "pinch" bolts (see first pic) or else it probably won't budge.
    Down to tighten, up to loosen ( if wrong ~ reverse procedure )
    The bolt head right in the middle of the carrier is a stopper bolt so you can't rotate the carrier around and around.
    john
    http://houseofmotorcycles.bikebandit...r-1984/o/m1908
