Results 1 to 14 of 14
Thread: feels like its runnin outta gas
    Cincinnati, OH
    3,289
    ever since tf last year the 450r has been runnin like *Edited**Edited**Edited**Edited* thought it was somthing in the carb took it of cleaned it everthing is fine. made sure the petcock was clean too.
    it runs good for a little bit then shuts off like its running out gas and i havnt messed with the car since i jetted when i put the sparks full exhaust and opened the air box lid up . oh and if you let it sit for a min then it will start back up and run good again then do it again
    so shoot me some ideas as whats up
    Sep 2005
    Lipetsk, Russia
    2,824
    Does it run longer if you blow into the gas tank vent hose while it's running?
    I'm back in the USSR...
    DIGGER DOG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    in the sticks s.w ga
    446
    am I to assume this is a TRX 450R?? sounds like your float needle is sticking or float level not to specs. It can also be a plugged vent tube at your gas tank cap .
    have you done a spark plug check after the pipe ,air box mod, and jet kit installation?
    It may well be running too rich fouling plug and after it dries it fires again?
    Is the plug brown ,white,or black?
    Brown = optimal,, white= too lean, and black=too rich.
    83 YTM 200,84 200X,,85 350X basket case,86 350X parts trike,86 350Xroller needs top end, 86 250SX,
    Jan 2008
    Connecticut
    27
    I'm not familiar w/ the 450r. what kind of carb does it have? or does it have plastic needle seat or is it cv operated? I had an 02 Raptor & everytime i let it sit with gas in the bowl for a couple of days I had to rebuild the carb. the gas these days has an additive or something and it eats plastic and tarnishes metal quickly. It would run similar to what your describing. It would run til the end of the driveway then die, i'd wait, start it and get it back to the garage and it would buck like running outa gas and sometimes back fire. I'd chech the needle seat, or just replace it. and make sure there's no tarnishing on the needle or anywhere elsle.
    Cincinnati, OH
    3,289
    carb is clean i have gone threw it 3 times now it may be the float as its plastic and yes jetting is good its been piped and jetting for a year then it started to do this.
    and no its not the vent for the take as i have ran it with the gas cap lose and it still does it
    na
    5,702
    Check the overflow tubes coming off the carb vents down to the swinger.
    They plug up with mud and cause these exact symptoms.
    We all know how bad Haspin mud can get!
    Proudly NOT a member of
    "Team on the Teat"
    Cincinnati, OH
    3,289
    thanks mosh i will check those
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Quote Originally Posted by moshman355 View Post
    This sounds like the exact problem, I've had to deal with this before. Is there a fuel filter on this? If there is, check it. It may be plugged, starving it of fuel, and after it sits for a bit gas gets by the junk and alows it to start. Just an idea....
    TF 07,08,09,10,11,12,13,14!
    AngusJustice is offline At The Back Of The Pack Arm chair racerFirst time rider
    Canada
    219
    I got the same problem with my 1985 250R It's been doing this for over a year and I still can't figure it out changed gas and tank and electrical harness run with gas cap off ran with overflow tubes off canged carbs everything I can think of please let me know if you find out the problem would be great to ride it again. went and bought a 1980 185 just so I knew what it was like to ride in the snow again!!!! Please Let Me Know If You Find The Problem!!!! Thanks A.J.......
    Columbia
    5,131
    Could be a clogged petcock............
    Jan 2008
    Tennessee
    28
    I have this same exact problem(or atleast the same symptoms)on my 125 m..cleaned the carb..new plug..has good fire..runs at an idle..give it throttle and it bogs and dies..will occasionly rev up for a second or two then dies..wait a few then it will fire back up..beats me
    Canada
    219
    3 of us with the same problem sounds like a gas issue maybe? All the bikes are different models someones got to know the answer! anyone with even the slightest idea whats wrong with these trikes please post!
    446
    Well the only other things i can think of that ahsent been posted would be check you gas it may be old bad gas and check every electrical connection , my old 200 x would run a bit sputter like running out of gas die cool off fire again my stator connections were loose
    Nov 2007
    N.Ireland
    119
    You can also check the exhaust, last year my wee lad's 50 just kept dyin, would start, tick over, rev a bit then die, few minutes later same routine.
    I checked fuel, carb, plug etc, took the exhaust off, it was so badly gummed up you could hardly slide a pencil down it. Soaked it, cleaned it, wee thing runs like a storm.
    I also had problems on the 185s with a sticky choke..
    just check everything, you'll get there eventually....
    '87 Honda CB550F Super Sport (Awaitin a restore..)
    '82 Honda 185s Wee Cracker
    '83 Honda 185s Stripped, ready for re-build...
    '85 Honda 70 Once he's off the quad...
    '85 Honda 200es In midst of re-build...
    '85 Honda 250r Runnin Sweet..
    '07 Honda 450fe 4WD workhorse
    '94 Suzuki LT50 Well, he has to start somewhere...
    If at first you don't succeed,
    SkyDivin ain't for you....
