saleen n around : NICE MUSTANGS!!
and lary, sweet rides man!
I have a 96 cherokee for off road duty.
a 2001 cherokee that is for daily driving (not mine)
1991 mr2. 7,000$ fully worked/built MCS stroker motor T4 50 trim turbo 46MM external wastegate Spec stage III clutch Fidanza flywheel KO Racing T1 titanium 3inch exhaust Greddy style IC Spal fan/shroud solid polyurethane motor mounts brass shifter bushings Walbro 255lph fuel pump VMAX Pinion gear steering upgrade KOSEI K1 16x8.5 rear wheels H&R coil overs TEIN pillow ball mounts HKS turbo timer Two'sRus MBC KO Racing 4 inch intake pipe K&N filter TRD short shifter
2500lbs, with the stroker motor I will have sunk 32,000$ total. Should be running again in may. Blew up 2 other engines in 2007, neither of them liked 30 psi
stroker motor is going to have full port and polish, 264 hks cams, 1 MM oversized ferrea valves, engle springs, 9,000rpm rev limit, fidanza cam gears, block is bored over .2 with forged pistons, eagle rods. Should handle 600 rwhp without real issues
click the link below for pictures of all the little parts/turbo kit/junk
http://www.mrtwo.net/galleries.php?gallery_id=27
jason
