For some reason, I am having trouble getting the right side case (clutch side) to seal properly. I used a new OEM gasket, but I still have some pinhole leaks where oil squirts out. I always cleans the surfaces well, even to the point of using a Dremel tool and small wire wheel. Should I use some gasket maker in addition to the gasket??? Is there something else you guys use? Thanks.
Kris
