Results 1 to 2 of 2
Thread: Ever reuse a piston?
    Nov 2002
    Chezzetcook Nova Scotia
    1,837
    I blew up the tecate and really cant afford to get a piston rings and a new sleve.
    So I want to reuse the blown piston. It is just lightly scuffed just to the point the rings stuck.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Dec 2007
    Prescott AZ
    99
    if your cylinder isnt scarred you dont need a sleeve, just a piston kit, but I wouldnt reuse the piston if the rings got stuck, it did start to melt. chances are if you clean it up and put it back in it WILL run BUT not for long and it will probably tear up the cylinder when it comes apart.......... check out your cylinder even if it has a little aluminum on it, you can still save it with a good honing as long as the NiCaSil plating is OK it will be fine...
    Current bikes:
    85 1/2 Tri-Z (black/red)
    84 T3 restored
    84 T3 unrestored for gettin'
    84 T3 money pit
    86 350X 13.5:1 full race
    84 250R beater
    96 blaster CT sonic 240 kit 38mm airstryker carb 42HP!!
    Past bikes:
    85 TRI-Z
    84 200X
    87 200X
    86 350X
    82 250R
    84 250R beater
    84 TRI-MOTO 125
    83 ATC 110
    70 US 90
    87BW 200( I know its not a trike but...)
