Results 1 to 15 of 17
Thread: Should I lube my ATC200 pull start mechanism
    WaimakRydah's Avatar
    WaimakRydah is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    New Zealand
    421
    i have an 85 ATC200S which starts fine but the pull start does not go back in completely by its self i have to assist it. But as many of u probably know there is a hole located on the pull start drum cover at the top is the purpose of that hole so i can spray CRC down there or lube it in some way?
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    use white lithium grease, it wont break down the rope and lasts through water and elements
    Apr 2008
    New Zealand
    421
    Quote Originally Posted by Twilight View Post
    should i spray it down that hole at the top?
    and ive owned the trike for 4 days and the previous owners say it has a new pull start drum so it should have plenty of life left in it
    1985 Honda ATC200S
    1994 Kawasaki Eliminator EL250
    Nov 2002
    Kirkville, NY
    3,831
    That hole is for the decompression cable, not having one is not that big of a deal but don't spray anything down there instead plug it up.
    I would take is apart, clean, re-grease, install a new rope, and re-wind it. It's kind of a pain to do but I think there is a how to posted here some where.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Apr 2008
    New Zealand
    421
    Quote Originally Posted by thefox View Post
    would a decompression cable make pull starting much easier?
    1985 Honda ATC200S
    Nov 2006
    Seattle
    1,552
    Yes it would, it relieves the compression so its easier to pull.
    Apr 2008
    New Zealand
    421
    do u know how much it would cost to get one roughly? and do u think it would be worth the money?
    1985 Honda ATC200S
    Sep 2006
    S.E. LA
    700
    It doesn't make that much of a difference and IMO it is not worth the hassle.
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    Nov 2006
    Seattle
    1,552
    yeah just plug the hole.
    Its there so there is less strain on the pull start. Thats one reason why so many pull starts are broke and raped............
    Mar 2008
    Tug Hill
    1,282
    it is nice to have the decompression cable but if your easy on the rope you dont need it...it probably just needs to be rewound.
    Apr 2008
    New Zealand
    421
    just took the ATC down 2 the river and it went fine and the rope went in by its self and i taped the hole over and it worked better then usual
    1985 Honda ATC200S
    Sep 2006
    S.E. LA
    700
    Do you have a manual for your trike yet? There is LOTS of good info in their. I have a manual for every atc/atv I have and read them all often. They are a MUST have in my opinion. If you don't have one there is a guy on this forum that has them you can download.
    '04 EZGO TXT
    Former trikes;
    Apr 2008
    New Zealand
    421
    Quote Originally Posted by bigreddaddy View Post
    Na it didnt come with a manual and i aint bought one. Can u give me his username or send me a link for an 85 ATC200S manual? thanx
    1985 Honda ATC200S
    NE Arkansas
    2,344
    You can use the decompressor manually if you like. On the right side of the motor when your sitting on it. There is a lever on top of the head, just flip it all the way back to ya. It will decompress for 1 pull of the rope. Neither my 200S that I had or my current 185S have the cable, and I never use the decompresser, I just make sure they are tuned good enough to start within a couple pulls, to save my arm.
    Most of the cables were removed and left of if a person had to take the recoil off to change the rope or remove the recoil for some reason. It was just quicker to throw the recoil back on there and ditch the cable and tape up the hole.
    My Rags
