I GOT AN IDEA,,, SO I AM RUNNING WITH IT,,, its to hot to ride in the summer here,, unless you could ride inside right? well there is a place to ride inside ,, so i am building an indoor ATC70,, i can't approach the guys till i actually have a trike to ride ,, so here it goes ,,, maybe i can stir up some interest just for a fun time can you imagine 10 guys going at it for 30 laps on one of these????? it should be ready for a test run this weekend!!!
i took a throttle off a CT 70 its a twister with the cable inside the handlebars,, so no visable cable,, i took the brake lever perch off and built a foot brake so no cables off the bars i built a small tucked in little pipe so it would be out of the way and no burns,i sent the axle out to a machine shop and turned it down to 1" so the gokart hubs would slide right on..i will cut keyways when i figure out where the hubs will be , i have to build a seat ,, the stock pan is to wide so off to bobs i go,, motor is all stock 70 cc,, should be a blast to ride,,,,,,,,,,,,
: yer one fart smeller Billy
