Results 16 to 30 of 43
Thread: Pics of my atc 500r project
    Aug 2004
    Cedar City, Utah
    474
    that forward kick setup is awesome! great work. thats one of those things many of us have day dreamed about but never went beyond that. lol hats off to ya for pulling it off. HH
    Seeing this thing has got me thinking about my 500. I almost had it together, but then it kinda ended up on the back burner. I was almost thinking of ditching it, but this post actually got the wind back in my sails. Still won't be for a little bit (got a few projects), but at least now I know I don't wanna sell it.
    Nov 2006
    Ga
    103
    I was worried about the mechanism holding up because of the obvious extreme pressure on it, but it does not flex, bind or feel any different than the standard rear kick thanks to the large ball bearing system it uses. I am glad that I chose the forward kicker because I did have the option of sticking to the rear kick, but when I get the cover built and a slightly modified kicker arm that matches my plastic, it should have a nice OEM look.
    84 Tri Zinger 60
    84 ALT 125
    84 ATC 110 (blue)
    85 YZ 490
    85 ATC 125M
    85 CR 500
    85 Tri Z 250
    85 Quadracer 250
    86 Tri Z 250
    86 ATC 350X
    (2) 86 ATC 250R
    86 Tecate 250
    87 ATC 200X
    87 ATC 250SX
    (2) 87 Big Reds
    88 Quadracer 500
    01 CR 500 (new)
    04 KX 500 (new)
    06 Banshee SE (new)
    07 CR 125 (new)
    07 CR 250 (new)
    Jackson MI
    1,688
    Thats a very slick guy that did the kicker mod. One thing to think about Is the posabilty of changing the gear ratio to make the mighty 500 kick easier. Kinda like changing you sprocket size. Thats a nice build right their.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Las Vegas, NV.
    2,516
    The forward kickstarter is a very trick problem solver. It looks like a cover for the mechanism is a must, unless you want crud inside the bearings. Good looking build, keep us updated.
    Nov 2006
    Ga
    103
    It actually uses a sealed bearing, so no debris can damage it. The only parts that are exposed are the two gears that mesh, only a minimal amount of damage could be expected from debris on the gears (as long as nothing major was in there) and it would take a long time since they spin relatively slow and only turn a 1/4 to 1/2 revolution. A cover is definitely in the works though.
    As far as changing the gear ratio of the kicker we chose to leave it a standard 1 to 1 because if I geared it to spin the motor over easier, then the motor would not turn over as quickly without increasing kickstarter speed and if you geared it the other way to spin the motor more quickly, it will become too hard to kick period! So basically the shorter kicker of the 250r does not provide the same amount of leverage as the longer bike kicker, but it is still very manageable.
    84 Tri Zinger 60
    84 ALT 125
    84 ATC 110 (blue)
    85 YZ 490
    85 ATC 125M
    85 CR 500
    85 Tri Z 250
    85 Quadracer 250
    86 Tri Z 250
    86 ATC 350X
    (2) 86 ATC 250R
    86 Tecate 250
    87 ATC 200X
    87 ATC 250SX
    (2) 87 Big Reds
    88 Quadracer 500
    01 CR 500 (new)
    04 KX 500 (new)
    06 Banshee SE (new)
    07 CR 125 (new)
    07 CR 250 (new)
    Masshole
    2,191
    If you dont mind me asking, what are the gears from? are they tranny gears, and how is the one that is on the motor attached? is it welded to a stock 500 kicker knuckle?
    Aug 2004
    Phoenix
    1,226
    Very creaive work/idea! I've seen alot of CR500 builds in 3 wheelers, but your the first one I've heard of tackling a custom forward kickstarter. Way to think out of the box..Hopefully it will holdup to regular riding.
    4 Strokes are NOT the wave of the future!
    Maryland
    3,077
    That forward kicker is the BOMB! Very awesome! Welcome to the 500 club! lol
    Sep 2006
    Northwest Indiana
    1,893
    Awesome build, and pure genius on the kick mechanism. I can already see that bike fully restored and pounding on unsupecting prey!!! Any yes, the oem look will be very slick! Hats off.
    Feb 2005
    Orchard Colorado
    659
    Nice idea on the kicker.
    I think that may have solved the problem that I've had for the '83 480 CR. If you made 2, can you post some close up photos?
    '85 Cagiva 200
    '86 Cagiva 500
    '82 ATC 480R
    '83 ATC 250R DG
    '83 Nicholson 185s
    Owned 5 Franks, sold 4, have one left.
    NY
    3,185
    Wow I missed this thread ...super build!!!!!!
    Aug 2006
    NW Ohio
    1,043
    awsome build but would like to see some pics of the underside of the frame!
    ATC500AF
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    im interested in the details on the pipe, i though you had to get a custom handmade jobby for the conversion. that is an atc frame right?
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
  15. #30
    Glendale, AZ
    101
    Sweet! Nice job on the kicker! I need to get going on my conversion, yours is good inspiration.
    1985 ATC 250R
    1985 CR500R
    2000 CR500R
