Results 16 to 30 of 35
Thread: 350x carb upgrades?
    Dec 2006
    Las Vegas, NV
    418
    so what do you do with the electrical connections on the carb?
    85 350X, 85 250R, 99 TRX 90, 05 Predator 90, 05 TRX 400ex, 2019 RZR4 XP100
    FEEDBACK for Vegas250rr
    Fresno Ca
    2,695
    cut the wires, Tape/ziptie them up out of the way. The Fcr carbs are just a TPS (throttle position senser) and it dosent affect the function of the carb at all, On the 04/5 trx carb one is a tps, the other is a fuel heater (dont ask me about that one) and i have never hooked them up.
    Dec 2006
    Las Vegas, NV
    418
    ok, what about the dual cable setup... am I stuck with a twisty or can I make my thumber work? I am looking at one with a HOT START cable attatched... what the heck is that thing gonna do for me?
    PA
    3,515
    think of a hot start as the opposit of a choke
    a choke is for cold starting....a hot start is just that, if the motor is hot and its a pain to start you just hit the hot start.
    WWW.HREATV.COM
    Dec 2006
    Las Vegas, NV
    418
    what does it do ? (what makes it easier to start when its hot)
    PA
    3,515
    well instead of makeing a richer mix like a choke the hot start will let air in (leaner mix)
    if you dont have a problem with starting it hot then just dont use it or worry about it.
    on a large (460cc) 350x motor it is a handy thing to have.
    WWW.HREATV.COM
    Oct 2007
    Grosse Tete, LA
    3,439
    Buy the 450r switch pod like I did and you can connect the cables... The hot start I mean. Buy a 450r throttle and the cable will connect no problem. I have a near brand new 450r twisty if anyone wants it. Very cheap. 20 shipped. Less than 10 minutes on it.
    Feedback thread: http://www.3wheelerworldforums.com/s...ad.php?t=78535
    Patiently waiting..
    Fresno Ca
    2,695
    If you use a 06 and ^ trx450 cable, it will go right in. You only use the pull side. And you close up the other side (with silicone) where the close cable would go.
    The hot start just lets more air past the carb, just like swigin said. This makes the mixutre leaner. Easyer to start under hot conditions.
    Really you dont need the choke with the acclerator pump carbs. Just pump the gas 2 times and bam, its done.
    Feb 2009
    New-Brunswick,Canada
    9
    i have a 400ex carb on my 86 350x, it work A1
    Dec 2002
    Orange County, NY
    1,772
    This 450 carb sounds like a great set up. I like my 38 but the X can be a bear to start sometimes when its been going for a while and is good and hot.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Oct 2007
    Grosse Tete, LA
    3,439
    NO NO NO
    You want the cr250r carb...which is a 37mm. You don't want the 41/42. the first problem with the 450r carb is fitment...the next problem is that it's all top end.
    NOS-350x did it...I had already purchased one by the time I read his review, I did it...and it really is too much carb for a stock sized engine.
    big bore with heavy portwork and such might be a different story, but on the stocker, it's too much.
    Patiently waiting..
    Fresno Ca
    2,695
    CRF250r
    Yz250F
    RMZ250
    Those are the carbs that you want.
    The 450 carbs are going to be too much, Even for a big bore, these are old engines, they dont rev like the new ones so the huge carb is unnessary when your engien isnt capable of getting rpm's to get the advantages of a huge carb.
    Dec 2006
    Las Vegas, NV
    418
    well I bit the bullet, I got the carb (02 yz250F) and it comes with all cables and a brake perch with hot start button. now all I need to do is get all things together and tune her up!
    Dec 2002
    Orange County, NY
    1,772
    Ahhh. Thanks for the heads up. I guess I'll just keep my 38 then.
    John
    1986 Monstecate
    1984 ATC125M
  15. #30
    Oct 2007
    Grosse Tete, LA
    3,439
    can someone explain to me what the hell all of the jets do? I see the pilot, I see the main, I know the needle. Now there are two other jets I don't understand. One...NEXT to the pilot, a short mikuni style. The other in the carb intake coming from the airbox.
    what are they, and what should they be tuned at?
    Patiently waiting..
