Page 3 of 3 FirstFirst 1 2 3
Results 31 to 35 of 35
Thread: 350x carb upgrades?
  1. #31
    Fresno Ca
    2,695
    Starter jet, is next to the main and pilot. Air idle circut jet, Is on the airfilter side of the carb. and the one in the bowl is a leak down jet for the acclerator pump.
  2. #32
    Dec 2006
    Las Vegas, NV
    423
    well finally got it installed... runs like a scared rabbit, just need to fix the bobble when I stab the throttle.
    85 350X, 85 250R, 99 TRX 90, 05 Predator 90, 05 TRX 400ex, 2019 RZR4 XP100
    FEEDBACK for Vegas250rr
  3. #33
    Eastern shore of Maryland
    3
    Bringing this back up to the top.
    I have a stock 86 360x and the OEM carb keeps having float issues so I want to pull it off and put it on the shelf and replace with something. Per this thread it seems the FCR 37mm is the best. Do I need a new throttle cable to do this upgrade? I want to keep the thumb throttle. I understand that the FCR has the dual cable and you just plug the "down" cable hole side. Basically my question is, will my stock thumb throttle cable attach to the FCR no problem or what do I need to buy at the same time to make this setup work?
    Thanks
  4. #34
    I run the FCR's on a few of my ATC's - 32mm, 39mm and 41mm.
    They all run the stock OEM ATC cable and throttle, I just silicone one of the holes shut on the FCR carb plastic cover.
    The FCR carb is great, performance and lots of adjustability, too much sometimes; But, be aware that it is very big, much bulkier than stock. I built all my own intakes and could angle them/shorten or lengthen them as needed. I had to or the carb would hit something. Be aware that cable fitment may not be the only issue, it may require more work if you want to use your stock air box etc.
    Your OEM 350X carb is desirable, easily rebuilt and will run as it should. An aftermarket/clone 350X carb is worth about 25$
  5. #35
    Nov 2019
    Florida
    1,053
    Www.223cycle.net pick up a 400ex carb.
    You will be happy you did.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
