So,.. what works on the 350x for a upgraded carb? 450r? 400ex? I want something that is better overall, not just for high end power. I still want to have a good trail trike. Anything i should stay away from?
im pretty sure i was told to use a 400ex carb and that you can get them cheap "ebay i guess" i ended up getting a makuni carb with a bunch of 350x parts im going to try out when the bike is done.
05 Kingquad 700 85 200x 85 250es 85 350x
85 350x rider project 85 350x (project) watch the progress here http://3wheelerworldforums.com/showthread.php?t=85959
Goin to prove you can polish a turd "so far it takes a lot of cash to buff that brown out'
400ex carb
Rides
85 ATC350X
85 ATC200X
no, 37mm fcr, once you get one you'll never look back. That's after the 400ex and 450r carb...
Nos-350x was right concerning this. They are the best.
Feedback thread: http://www.3wheelerworldforums.com/s...ad.php?t=78535
Patiently waiting..
Ive ran all that are mentioned.
The 04/5 TRX450 carbs are WAY too much for our little 350 engines.
The 400ex is a good new replacement for the 350x carb, They work good, and all the adjusments are new. So it tunes easy, and is easy to work with.
If you got the money go with a carb off of the 250Fourstroke MX dirbike. That is a PERFECT carb for our engine. 37MM or 38 FCR carb is the grand daddy of carbs for the 350x. the 39 and 41's are too much for the enigne.
How much do one of those carbs go for??
TF 07,08,09,10,11,12,13,14!
I will say that the 04/05 carb makes the bike downright explosive...you have zero torque one second and the next hang on for dear life.
poo on that.... 37mm all the way.... run you anywhere up to 180...and worth every penny.
Patiently waiting..
one thing I am curious about is which thumb throttle works with this carb?
Patiently waiting..
I ve used a stock 350x thumb throttle with a 06trx450 cable, (the other inlet on the carb for the push pull system just put some sylicone stuff over it)
They make a nice fuel resistant sealer. Haven't done it yet, still constructing.
Patiently waiting..
I have a 38mm Keihin PE on mine. I ordered it years ago from Duncan Racing. They got the jetting pretty close out of the box and will ship you a jet/needle kit with it.
John
1985 Eddie Sanders ATC330r
1986 Monstecate
1984 ATC70 (awaiting 125cc transplant)
1984 ATC125M
1986 GSXR 750 - Keepin' it old school!
1999 Arctic Cat 500 4x4 plow machine
1999 Arctic Cat Thundercat 1000 (lake lizard)
1996 Arctic Cat Jag 440 L/C (ditch banger)
WWW.HREATV.COM
Tri-z none will touch fuel. This is just in the throttle cable linkage area. Since the carb has a 2 cable push/pull twist throttle system.
Carb buyers guide i put up on .org.
http://www.3wheeler.org/vb/showthrea...50x+carb+guide
