any one have good mods 4 the 225dx i have a supertrapp exhaust, k&n filter and running mod banshee hubs for more wheel and tire option's any other good ideas
I've seen heavy duty valve springs so if you run a hotter cam, the valves don't "float". I've also seen some pieces to mod the front forks. Cam and carb mods would definitely be next on the list though.
where can i get a hotter cam!!
There is at least 2 companies that make performance cam for the 225.
www.webcamshafts.com
www.megacyclecams.com/
You may try Powroll also.
1984 Yamaha YTM-225DX
Québec 3-wheeler riders group
thanks 4 the cam info any other good mods
As a newb to souping up trikes I must ask where can you go to get an aftermarket exhaust for a 225? I've searched around a little but came up with nothing.
YTM225DX
Work in progress.
Dennis kirk has a DG for 155.99 and a two cobra systems one is a quiet series for 157.99 or the megaphone system for 129.99 you can get it from your local power-sport shop if they are a parts unlimited dealer
what about a head light guard are there any??
could also do a wiseco piston kit for higher compresion
1985 Quad Killer
1985 Mini Raag
1985 Green Gobbin X2!!
1990 Kawasaki 300sx
R.I.P
what is stock compression ratio on the dx i called wiseco and they said their piston is 10.25:1 they said that is stock replacement!!!!!
the stock comp ratio is lower than the 10.25 to 1. i dont remember the stock ratio but i do know its not 10.25 to 1.
wiseco said no performance gain with there piston
look here for your comp ratio.
http://www.3wheelerworld.com/1985yamahaspecpage.shtml
thanks but it said "compression ??" no help
" 2 STROKE 4 LIFE "
85 Yamaha tri-z 490 dirt dragger
86 Suzuki lt 250r (every day rider)
92 Suzuki lt80 (daughters dirt dragger)
96 Polaris trail blazer 250
i have a headlight gaurd, 25.00 plus shipping from 42025
