Results 1 to 15 of 15
Thread: Another way to repair threads: - time-sert tutorial
    Aug 2005
    Lockport, NY
    2,395
    Unfortunately, a lot of recreational vehicles use aluminium for their cases. Doing a bolt up tight in an aluminium case can very easily result in stripping of the threads in the case. In these situations you have to resort to using a thread repair kit to recover the cases, or you just have to bite the bullet and buy new cases. There are multiple ways to repair a thread. Heli-coil, recoil, staked inserts,etc. I prefer the inserts made by Time-Sert. They far exceed a heli-coil in every aspect. Lets take a look at how it actually works.
    Determine the size of the kit you need:
    For experts in sizing bolts, you can skip over this part. I've included it because I think it's important to show to newbies how you do this sort of stuff.
    In this case, I'm doing a motorcycle sump plug. I know that it is a metric bolt, and grabbing the trusty vernier calipers says it has a diameter of almost 12 mm (so it is an M12 bolt) and each thread is separated by ~ 1.5 mm, so it is an M12x1.5 mm bolt.
    Measuring the diameter of the bolt. Nearly 12 mm means this is an M12 bolt.
    Measuring the thread pitch. The image below shows where you measure on the threads - it's from one point to the corresponding point one thread up. This measurement is how far the bolt will insert for one rotation, if you'd prefer to measure it that way.
    Here's how you measure the thread pitch. In this case, I'm measuring from the bottom of one thread to the bottom of another.
    Pretty simple. But, like I said, I wanted some photos to show people how you measure these kinds of things.
    Find an appropriate insert kit
    There are a number of insert kits available. Common ones are Helicoils and Recoils, which are very similar, and the Time-Sert kits.
    I am using a Time-Sert kit in this case, as:
    It is a solid insert so it has less chance of leaking oil
    It has a tapered top so it has less chance of being wound into the crankcase after installation
    It features an installation method that grips the entire way around the insert, making it more difficult for the insert to come out whenever the sump plug bolt is removed
    The insert is installed using the entire body of the insert, not a tang, so there's no chance of the tang snapping off halfway through, buggering the install, or bouncing into the crankcase necessitating splitting the cases to remove the little bugger.
    A major downside to the Time-Sert kits, however, is that they tend to be expensive. Most local bolt shops should have all of the types, and you can also order them over the internet, for example, you could get a Tme-Sert kit here. Speak to a bolt place or someone with lots of knowledge on this (more than I have, for example!) before you decide which kit to go with.
    No matter the kit you buy, you can chose to buy them either as a kit for a single size or in a multitude of sizes. The kits with many inserts are good economy if you think you'll be repairing a lot of different bolts. Me, I tend to aim to get only the sizes I need. For this project, most of the insert kits only have inserts up to M10 anyway so you need to be separate kits for the big sizes. More often than not big bolts, unfortunately, seem to be the ones I see stripped.
    Contents of a kit
    Contents of a single Time-Sert kit (I bought additional and longer inserts though)
    Inserts. On the left are the 9.2 mm drain plug inserts that came with my kit, and on the right the 15 mm inserts I purchased separately.
    I bought a kit which came with 9.2 mm inserts (it is intended to be a drain-pain installation, so they are quite short). Just in case I needed deeper ones, I also grabbed some 15mm inserts. Inserts are cheap once you have the installation tools.
    Drill bit from the Time-Sert kit
    You use the drill to remove all of the old threads in the hole. You also want nice clean sides to the hole to make it easier to tap in the threads for the insert.
    Countersink bit from the Time-Sert kit.
    This is contained in the Time-Sert kits and not the other types of insert kits. The tapered top to the Time-Sert means you require a countersink portion at the top of the hole to make it work.
    The Time-Sert insertion tool.
    To Be Continued...
    PLEASE DO NOT POST
    Aug 2005
    Lockport, NY
    2,395
    This is another difference between a Time-Sert kit and a Helicoil or Recoil kit. Helicoils have a little tang at their bottom that you use to install it. The Time-Sert uses this slightly oblong shaped (in cross-section) threaded insert tool which cold-rolls the inner threads of the insert and forces the insert out into the outer threads, making for a tighter fit. If you look closely at the inside threads of the insert, you'll see they're not fully cut, and they slightly taper smaller at the bottom.
    Internal threads for the Time-Sert insert.
    Because the insert tapers very slightly, and the threads are not fully formed on the inside, the insertion tool will actually roll these threads out, press the outer threads into the threads you cut in the hole and generally expand the insert so it holds on nice and tight.
    You can also tell that there's something odd about these inserts before they're installed - the original bolt won't fully go into them.
    Insert on the sump plug bolt.
    Note that when the insert is installed properly, this bolt will properly tighten through it - but the act of insertion changes the shape of the insert, which then makes the original bolt fit properly.
    Other things you'll need
    Tap handle
    Taps, and even the drills in this kit, have square ends to their shanks. A special type of handle is designed for grabbing this. You can improvise with a shifter, which I had to do for this install because my tap handle didn't go big enough. Tap handles do make it easier to spin a tap evenly. I'll discuss tapping technique presently. If you have never seen one, here's what they look like.
    Grease
    When you're cutting metal, as you're going to be lots of times with these kits, a lubricant is necessary. Most tapping tools will tell you to use a certain lubricant for best tapping, for example, kerosene to tap into aluminium. That's all well and good, but a normal lubricant will spread your shavings (affectionately known as swarf) everywhere. If you use grease all of the swarf gets stuck in the grease, and you don't end up with swarf in your crankcase. This is clearly a good thing - swarf in crankcases tends to destroy things like bearings, and is a pain in the arse to get out unless you split the crankcases or fill it repeatedly up with diesel then flush with lots of motor oil. Diesel and motor oil cost a lot more than the grease you use on these kinds of tasks.
    I used high temperature wheel bearing grease for the pictures in this tutorial for no other reason than that is the only grease I had at home. Anything should do, as long as it is sticky (and all greases are!)
    Oil
    The insert tool requires use of oil. I just used motor oil but you could use a specialist cutting oil or even sewing machine oil if you were anal or didn't give two hoots, respectively.
    Rags
    Grease is messy. Rags clean up mess. You'll also collect loads of swarf, and it's handy to wipe that off with a rag, too.
    Clamps
    No matter what people say, you need to clamp your work down when you're tapping threads or even trying to use a big, sharp, coarse drill bit on an already enlarged hole. A drill press is ideal for some of these tasks, but that assumes you either have a very small motor, or a big drill press, and also that you don't mind swarf getting into your motor as it'll have to be upside-down (unless you can turn your entire drill press upside-down, in which case, you probably already know how to do this so stop reading the tutorial).
    Using a Time-Sert kit
    This is easier than you think
    Here's a quick before shot of the hole.
    The threads in the hole I'm using for this tutorial aren't too bad, but it's useful to practise on something before trying to do this on a real life engine that you'd have to fully dismantle and buy new cases for if you cock it up.
    2. Clean out the old threads
    Use the supplied drill bit for this. You can either drill this by hand (hard to do!) or do it VERY slowly with an electric drill.
    Coat the drill bit in copious amounts of grease.
    Drill bit with lots of grease on it.
    Make sure you keep the drill bit perpendicular to the surface that the bolt head will bear onto. If you get this wrong, you'll bugger up the tapping and, quite frankly, you'll end up having to buy the next size up insert kit and you'll feel like a bit of a fool. Keep it straight! A helper is good here; they can tell you if you're getting off line. I tried to teach my pooch to tell me when I was offline but he just went back to gnawing on a bone.
    Drilling the hole to clean out the old threads.
    Work the drill slowly in, and if it gets stuck, don't force it with more power, run the drill bit backwards to break any chips out. It can take some time, but just keep working it backwards and forwards, always turning the motor slowly. Don't spit swarf everywhere as it'll flick around outside and into your eyes (unless you have safety glasses on in which case: good man!) and also flick off the end of the drill bit inside the engine, spreading swarf inside your motor.
    Swarf on the end of the drill bit. See, grease works!
    At the end of it, you should have a nice clean hole. You have may have a small ring of debris around your hole, but hey, nothing some rags can't clean up.
    The hole, with all threads removed thanks to the drill bit.
    To Be Continued...
    PLEASE DONT POST
    Aug 2005
    Lockport, NY
    2,395
    3. Countersink the hole
    Coat the head of the countersink tool with grease to contain swarf. If you don't, PLEASE wear safety glasses - this tool flicks a lot of metal around.
    Grease on the end of the countersink bit.
    This tool produces a fair amount of swarf quickly, at least it stays on the outside of the hole.
    If your grease is sticky enough, it'll also stay on the end of the countersink bit.
    Keeping the countersink bit perpendicular to the surface, work it in and bore until the bit will not let you bore any more.
    Clean up the bit and the hole. You now have a clean hole with a countersunk section at the top.
    Beautifully countersunk hole.
    4. Tap the threads for the outer part of the insert into the hole
    Here's the really fun part. This is not the time to be learning tapping a thread 101, but I'll give you the lowdown on that first.
    There are two schools of thought on tapping threads: one is to just go at it as quickly as you can, smoothly, and keep it straight, and the other is to go forwards half a turn, then back a quarter of a turn, all the way through the hole. The first style seems to produce really smooth, nice looking threads. The second style is what most schools will teach students. The first style really needs high-speed steel taps, tapping in soft materials like aluminium, the second style will work on almost anything you can tap.
    I work somewhere in the middle. For cutting threads for an insert kit you want slightly coase edges to the threads so it's got some grip. You also don't want all the swarf going into the motor, so you don't want to just do it in one fell swoop. I go in a few turns to really cut some threads, then back it right out, clean out the flutes, relubricate, then cut more threads.
    In case you're going "huh?" about the word flutes in this context, they're the cut out bits on the tap that hold the chips as they come away from the metal on the sides of the hole you're tapping.
    The cut away pieces of metal in the tap are called flutes. They serve to extract the swarf as you chip material from the sides of the hole.
    Thread tapping 101
    Tapping a thread is pretty easy.
    You start by ensuring the tap is square to the surface - that's what your tap guide is for! Use it!
    Make sure you've got a suitable lubricant on the tap, both in the flutes (which collect the metal you cut out) and in the cutting teeth (which are what need lubricating).
    With the tap out, you can see all the material that's collected in the flutes. Clean it out.
    Swarf collected in the tap flutes. This again shows the reason I use grease.
    Relubricate, and repeat. Take it easy - you can go really slowly and do it half a turn forwards, all the way out, clean out the swarf, etc, or you can take a few turns then back it right out. The further you go the more chance you have of getting swarf into the motor and the more chance you have of binding the tap and snapping it. You have been warned.
    If you're doing this in a drill press, you're tapping into soft aluminium, you are confident, and your tap is a high-speed steel one, you could go full speed and do it in one fell swoop. But, hey, if you were that confident, you might not be reading this guide, and you certainly wouldn't be doing it on an engine in-situ, so this guide probably isn't for you.
    After a while you'll realise you're cutting no new material. This will feel nice, as the tap will never get tight as you turn it. Congratulations, you have tapped a thread.
    If you haven't ever tapped a thread before attempting to tap one for a thread insert kit I'd suggest picking up some scrap metal and a cheap set of taps and practising so you know what it feels like.
    With the tapping done, clean up that hole and check out the threads.
    Threads ready for the installation of the insert.
    You now have a hole, which has a countersunk top, and has the outer threads for the insert cut.
    To Be Continued...
    PLEASE DONT POST
    Aug 2005
    Lockport, NY
    2,395
    5. Install the insert
    The Time-Sert kit is VERY specific on this: USE OIL ON THE INSERT TOOL. Seriously, it's not hard, read the instructions, and do it. You're not really cutting metal so you produce no swarf, so use nice oil for this, not grease.
    It's also advantageous to use a tap handle for this as you spin the tool around a lot and it's easier to do with a proper tap handle. My M2-M12 tap handle fits the insert tool nicely, just not any of the other tools in the M12 Time-Sert kit.
    Insert tool in a tap handle.
    I'm using my long-handled tap handle here, just cause I can.
    Oil up the threads, and screw the insert on. For a Time-Sert kit you'll engage maybe two or three threads on the insert before you can't do it up with your fingers any more. This is normal. A Helicoil would differ to this a fair bit: with those kits you'd put the insert onto the insert tool, and turn it, then turn it backwards to snap off the tang once you're done.
    Screw the insert into the hole using the insert tool. After a while the threads will catch on the outside and the insert will stop spinning, and the insert tool will start to spin. This is the bit where the insert tool cuts the last of the threads in the insert and cold-rolls the sides into the threads. The insert will start spinning again into the hole, and then the insert tool will spin inside the insert, blablabla. Keep doing this for a while.
    Insert almost fully seated.
    Keep going until the insert completely bites into the taper at the top and is fully seated. At this point, the tip of the insert tool will only be at the bottom of the insert
    Insert tool, the end of which has just made it through the insert.
    Now you keep going with the insert tool, to really work the threads. It will slowly get easier to turn, to the point where it will be very easy to turn.
    Insert tool after fully expanding insert threads.
    The threads are nicely expanded to catch into the outer threads, and the inner threads are the right size for the original bolt.
    You're done! Install the original bolt back into the sucker to the proper torque, and don't rip this out.
    Finished insert!
    I did a bit of a test though. This particular sump plug is mean to go in at 20-25N.m, 14-18 lb.ft. I did it up to minimum torque, no problems. Maximum torque was no problem. Double maximum torque no problems. Quadruple maximum torque was a problem - I stretched the sump plug. I got it back out, and a new one installed perfectly.
    These are definitely stronger than the threads cut straight into the aluminium.
    Enjoy Trikers...
    racerxxx's Avatar
    racerxxx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Pennsylvania
    383
    Thumbs up
    Nice write up SX, My brother-in-law used the Time-sert for his spark plug threads in hi 97 Expedition. It's common for them to blow the sparkplug right out of the head! Happend to him 1/2 way back to NC from PA. They make a killer kit, anyone who needs to do thread repair should check out their stuff.
    By the way nice engine turned table "playa". Dude your all first class!
    That's meant as a compliment.
    1985 Honda 125M (My first Trike--Still have it)
    1986 Honda 250SX
    1981 Honda 110
    1982 Honda 110
    1986 Yamaha YFM80 (Sons quad)
    Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
    1987 CR-80, 70's vintage XR75, RM 370
    braunz200x's Avatar
    braunz200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Toronto
    158
    nice work and sweet write-up
    cybrman's Avatar
    cybrman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Winter Park, Florida
    254
    I went to make popcorn halfway through. Great stuff!! Thanks for the well written tutorial. I am going out tomorrow and buying some easy outs and a kit....you oughta be in sales!
    1985 250SX #2 300sx risen from the ashes.
    1985 200X
    1983 200
    1979 ATC70
    1985 ATC70
    1985 ATC110
    1985 Big Red
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Great thread, very informative and easy to follow with the pictures and descriptions. Moved it to the WCH forum
    Aug 2005
    Lockport, NY
    2,395
    Glad you all enjoyed.
    I have mentioned these in passing before. So I decided I would do it up.
    Sep 2006
    Northwest Indiana
    1,893
    Yes, time serts are great. Used them before on a cylinder that wouldn't hold studs any longer. Great step by step, and fantastic info!
    Aug 2005
    Lockport, NY
    2,395
    Quote Originally Posted by cybrman View Post
    LOL thanks man. Post up how you make out with the kit! I wanna know if you like them or hate em'!
    Very nice tutorial Jeff.....
    I've never tried these but I'm sure they work very well.
    At the shop I worked in, we used helicoils exclusively. The ones I put in, seemed to last, the ones my machine shop manager put in, would back out and for the record, I never used loctite on them either.
    Anyhow, I'm just wondering what the kit costs?? I never buy the helicoil kits, I just buy the correct tap, use a drill I have in house and buy regular and longer inserts.
    I'm usually about 20$ deep into most sizes which is very reasonable.... but like anything else, they all have there place.
    Such as the Tri-Z footpegs that strip often, I'd NEVER use a helicoil in that application, but I WOULD try a solid insert like this "time-sert" in that application and I bet it would work great .
    I'd also be much more comfortable using these in a cylinder head or base stud area and especially and oil drain plug.
    Seems to me the idea is that the installation tool drives in the insert because the inner threads are not completely finished and then as you continue, it bottoms the insert and then finish cuts the inside threads.
    Is it just an 82 degree countersink?? or is it "SPECIAL"??
    My only other thought is - what is the wall thicknessof the time-sert?? Just like with helicoils, sometimes you have very little "meat" left in the part and can only drill it out so far - such as a carburetor float bowl with M4 threads and very little material left. I think the helicoils are a mere 1mm wall thickness, and carburetors in specific have barely enough material to use them.
    You'll have to ship me a kit so I can try it on a drain plug I'd like to fix
    Aug 2005
    Lockport, NY
    2,395
    What size you need big guy?
    Mar 2005
    West Virginia
    96
    Check this video out, it explains how to use time serts.
    http://www.timesert.com/video/StandardRepair.wmv
    Here is the kit prices from bike bandit.com
    T57001142 KIT OILDRNPLG M12X1.5 $50.71
    W56019-008 KIT,THRD RR, M8X1.25 $36.73
    W56019-006 KIT,THRD RR, M6X1.0 $35.63
    Great prices! Use it once and it pays for itself!
    Jun 2003
    Anchorage/Homer, Alaska
    480
    Very cool, excellent write-up!
    I'll have to try this out on my SX. The oil drain bolt is only held in by a few worn out threads and a large amount of Blue RTV.
    I've always used oil on my taps. Seeing how much debris is collected with grease is impressive; I'll have to try that next time!
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
