Page 4 of 13 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 46 to 60 of 185
Thread: Crf 450 05 T0 3wheel.....
  1. #46
    May 2007
    Orange County, NY !
    1,673
    Nice job there. Good luck and keep it going, hope you found a place to keep your projects.
  2. #47
    Jackson MI
    1,688
    Xmode, your frame Is a 02-04. The 05 frame has a different front engine mount, the bolt goes straight through the frame without mounting plate's. The reason It looks like he built negative rake Into his triple's Is because the CRF fork tubes are smaller In diameter at the top triple than they are at the bottom one. He Is setting his up In the beginning with the axle leading, so as long as he puts the top rear shock mount In the correct spot, he wont make the same mistake I did. I already had my rear shock mounted, so I couldn't tip the frame to set my rake and wheel base correctly. If he sets the frame up with steeper rake, the front lower engine cradle will be tipped downward slightly, but won't hurt a thing!!! Looks Nice Xmode!!!
    I will be starting to hack on my 05 frame as soon as I get caught up on a few project's. Here Is a pic of a 05 frame. They're alot lighter, and have a bit steeper rake angle.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
  3. #48
    Feb 2009
    greece
    102
    jason i didnt know that it was a 02-04...they told me that it was a 05....
    See My Project At http://www.3wheelerworldforums.com/s...ad.php?t=94144
    1986 Kawasaki tecate 3 250cc 2007 Yamaha YZF 450 2005 Honda cfr 450 x
  4. #49
    Feb 2009
    greece
    102
  5. #50
    Feb 2009
    greece
    102
    the front brake disk...finished!
  6. #51
    Feb 2009
    greece
    102
  7. #52
    Apr 2008
    somerset ma
    1,822
    Looks like it will be a nice machine when it's done,, keep up the good work
  8. #53
    Oct 2007
    Grosse Tete, LA
    3,441
    very very nice...
    how much for a set of triples shipped to the USA? lol
    I love that design
  9. #54
    Feb 2009
    greece
    102
    very very nice...
    I love that design
    goat i think that you are joking......you like my plates so much?
    rear shock crazy project....?
  10. #55
    Feb 2009
    greece
    102
    last days progress
    waiting for your comments.....
  11. #56
    Jul 2006
    looks awesome man!!!
  12. #57
    Columbia
    5,131
    Good job dude!
  13. #58
    Sep 2007
    oregon
    2,292
    those tripples are bad ass.... The rake is a bit wierd though.
  14. #59
    audioworks04's Avatar
    Oct 2008
    Kansas City, KS
    332
    looks like your planning on using the crf rear shock, any worries abou this with the extra weight that it will be carring? Im using a peps valved 400ex shock with a custom mount somewhat like jason's. My big issue right now, the only thing really stoping me from riding it is that i cannot fidgure out a decent air filter set up and my rear brake. I am using trx450r pegs(move the mount foward and down from the stock crf placement) and cannot fidgure out how to get a brake lever to clear with out making my own. I know that when speedbump did his cr250 conversion he tried using the stock cr pegs and did not like them at all.
    Good luck its fun and really exciting to watch come together especially after you can sit on it. just dont rush it.
    86 atc250r stock sand only
    88 NX250 mint rainy day
  15. #60
    Oct 2008
    Kansas City, KS
    332
    Also jason is right about the frame, mines an 05 and like jason said the front mount goes through a tab on the frame(no plates). Also if you plan to us the trx450r exhaust it mounted up great on my head pipe and all, just have to use an 06 and up trx450r or er water pump cover with a spacer on the impeller to get the radiator hoses routed around it.
