O.k., thanks bud.
O.k., thanks bud.
not sure if this correct but:
Tank Damper Rubber -- Lot of 2
Kawasaki Part Number: 92075-030
BB9
FITS:
Part # = 92075-030
Part Description = TANK DAMPER,REAR,RUBBER
Model Count = 28
G3SS 73 90 90SS BUSHMASTER DUAL PURPOSE
G3TR N/A 90 90TR BUSHMASTER DUAL PURPOSE
KLT110-A1 84 110 KLT110 UTILITY 3 WHEEL ATV
KLT110-A2 85 110 KLT110 UTILITY 3 WHEEL ATV
KLT110-A3 86 110 KLT110 UTILITY 3 WHEEL ATV
C2SS N/A 120 C2SS 120 ROADRUNNER STREET
C2TR N/A 120 C2TR 120 ROADRUNNER STREET
KLT160-A1 85 160 KLT160 UTILITY 3 WHEEL ATV
F3 N/A 175 F3 175 BUSHWACKER DUAL PURPOSE
KLT185-A1 86 185 KLT185 UTILITY 3 WHEEL ATV
KLT185-A2 87 185 KLT185 UTILITY 3 WHEEL ATV
A1 N/A 250 SAMURAI DUAL PURPOSE
A1SS N/A 250 SAMURAI SS DUAL PURPOSE
F21M 71 250 F21M MOTOCROSS
F4 N/A 250 F4 250 SIDEWINDER DUAL PURPOSE
F8 71 250 F8 250E ENDURO DUAL PURPOSE
F81M 71 250 F81M 250C MOTOCROSS
KXT250-B1 86 Kxt-250 TECATE SPORT 3 WHEEL ATV
KXT250-B2 87 KXt 250 TECATE SPORT 3 WHEEL ATV
KLF300-A1 86 300 BAYOU 300 UTILITY 4 WHEEL ATV
KLF300-A2 87 300 BAYOU 300 UTILITY 4 WHEEL ATV
A7 N/A 350 AVENGER DUAL PURPOSE
A7SS N/A 350 AVENGER SS DUAL PURPOSE
F5 70 350 BIGHORN DUAL PURPOSE
F9 72 350 F9 350 DUAL PURPOSE
H1 N/A 500 H1-500 MACH III STREET
H1B 72 500 H1 500 MACH III STREET
H1C 72 500 H1 MACH III STREET
OFFICIAL KAWASAKI.COM LIST
Model (25):
A1 (1969)
C2SS (Roadrunner) (1969)
C2TR (Roadrunner) (1969)
F3 (Bushwhacker) (1970)
F4 (Sidewinder) (1970)
F5 (Big Horn) (1970)
F81M (1971)
F8-A (1972)
F9 (1972)
F9-A (1973)
G3SS (1970)
G3SS-A (1971)
G3SS-B (1972)
H1 (Mach III) (1969)
H1-C (1972)
KLF300-A1 (Bayou 300) (1986)
KLF300-A2 (Bayou 300) (1987)
KLT110-A1 (KLT110) (1984)
KLT110-A2 (KLT110) (1985)
KLT110-A3 (KLT110) (1986)
KLT160-A1 (KLT160) (1985)
KLT185-A1 (KLT185) (1986)
KLT185-A2 (KLT185) (1987)
KXT250-B1 (Tecate) (1986)
KXT250-B2 (Tecate) (1987)
Says quantity (3) so maybe all 3 tank rubbers are the same?
86 T3
84 T3
86 KX250
what about carb options for the 86 t3 im always having some type of carb problem with and was wondering what else will bolt right up that is newer
Just about any 36-40mm carb should bolt on. Look for other peoples pictures.
The T4 engine is not the same the T3 engine (it is not a direct swap)
86 T3
84 T3
86 KX250
1986 KX125 uses same rear shock oil reservoir
86 T3
84 T3
86 KX250
13097-1084 GEAR-PRIMARY SPUR, 18 Tooth - gear off crank that drives clutch basket gear
Model (4):
KXT250-A1 (Tecate) (1984)
KXT250-A2 (Tecate) (1985)
So, to take a 1985-1986 KX250 motor and make it have gearing similar to the Tecate, you need this 18 tooth primary gear and a Tecate Clutch Basket and possibly the kick start idler gear.
86 T3
84 T3
86 KX250
600A1200 BALL STEEL 3/8' This is the ball bearing that is between the clutch push rod and push plate and appears to be Standard size and I think Kawasaki meant inches (")
All Ninja 250R up to 2005 and
KX250-C1 (KX250) (1983)
KX250-C2 (KX250) (1984)
KX250-D1 (KX250) (1985)
KX250-D2 (KX250) (1986)
KX250-J2 (KX250) (1993)
KX250-K1 (KX250) (1994)
KX250-K2 (KX250) (1995)
KX250-K3 (KX250) (1996)
KX250-K4 (KX250) (1997)
KX250-K5 (KX250) (1998)
KX250-L1 (KX250) (1999)
KX250-L2 (KX250) (2000)
KX250-L3 (KX250) (2001)
KX250-L4 (KX250) (2002)
KX250-M1 (KX250) (2003)
KX250-M2 (KX250) (2004)
KX250-R1 (KX250) (2005)
KX250R6F (KX250) (2006)
KX250R7F (KX250) (2007)
KX500-A2 (KX500) (1984)
KX500-B1 (KX500) (1985)
KX500-B2 (KX500) (1986)
86 T3
84 T3
86 KX250
Oil drain plug 92066-1241
Model (125):
AR50-A1 (1982)
AR80-A1 (1982)
KD80-N1 (KD80) (1988)
KD80-N2 (KD80) (1989)
KD80-N3 (KD80) (1990)
KDX200-C1 (KDX200) (1986)
KDX200-C2 (KDX200) (1987)
KDX200-C3 (KDX200) (1988)
KDX200-E1 (KDX200) (1989)
KDX200-E2 (KDX200) (1990)
KDX200-E3 (KDX200) (1991)
KDX200-E4 (KDX200) (1992)
KDX200-E5 (KDX200) (1993)
KDX200-E6 (KDX200) (1994)
KDX200-H1 (KDX200) (1995)
KDX250-D1 (KDX250) (1991)
KDX250-D2 (KDX250) (1992)
KDX250-D3 (KDX250) (1993)
KDX250-D4 (KDX250) (1994)
KDX80-A1 (KDX80) (1980)
KDX80-A2 (KDX80) (1981)
KDX80-B2 (KDX80) (1982)
KDX80-B3 (KDX80) (1983)
KL250-G4 (Super Sherpa) (2000)
KL250-G5 (Super Sherpa) (2001)
KL250-G6 (Super Sherpa) (2002)
KL250-G7 (Super Sherpa) (2003)
KL250-G8 (CANADA ONLY) (2004)
KL250G9F (Super Sherpa) (2009)
KL250GAF (CANADA ONLY) (2010)
KLX250-D2 (KLX250R) (1994)
KLX250-D3 (KLX250R) (1995)
KLX250-D4 (KLX250R) (1996)
KLX300-A10 (KLX300R) (2005)
KLX300-A2 (KLX300R) (1997)
KLX300-A3 (KLX300R) (1998)
KLX300-A4 (KLX300R) (1999)
KLX300-A5 (KLX300R) (2000)
KLX300-A6 (KLX300R) (2001)
KLX300A6F (KLX300R) (2006)
KLX300-A7 (KLX300R) (2002)
KLX300A7F (KLX300R) (2007)
KLX300-A8 (KLX300R) (2003)
KLX300-A9 (KLX300R) (2004)
KMX125-A12 (KMX 125) (1999)
KMX125-A13 (KMX 125) (2000)
KMX125-A14 (KMX 125) (2001)
KX100-B5 (KX100) (1995)
KX100-B6 (KX100) (1996)
KX100-B7 (KX100) (1997)
KX100-C1 (KX100) (1998)
KX100-C2 (KX100) (1999)
KX100-C3 (KX100) (2000)
KX125-D1 (KX125) (1985)
KX125-E1 (KX125) (1986)
KX125-E2 (KX125) (1987)
KX125-F1 (KX125) (1988)
KX125-G1 (KX125) (1989)
KX125-H1 (KX125) (1990)
KX125-H2 (KX125) (1991)
KX125-J1 (KX125) (1992)
KX250-E1 (KX250) (1987)
KX250-F1 (KX250) (1988)
KX250-G1 (KX250) (1989)
KX250-H1 (KX250) (1990)
KX250-H2 (KX250) (1991)
KX250-J1 (KX250) (1992)
KX500-C1 (KX500) (1987)
KX500-D1 (KX500) (1988)
KX500-E1 (KX500) (1989)
KX500-E2 (KX500) (1990)
KX500-E3 (KX500) (1991)
KX60-A1 (KX60) (1983)
KX60-A2 (KX60) (1984)
KX60-B10 (KX60) (1994)
KX60-B11 (KX60) (1995)
KX60-B12 (KX60) (1996)
KX60-B13 (KX60) (1997)
KX60-B14 (KX60) (1998)
KX60-B15 (KX60) (1999)
KX60-B16 (KX60) (2000)
KX60-B17 (KX60) (2001)
KX60-B18 (KX60) (2002)
KX60-B19 (KX60) (2003)
KX60-B6 (KX60) (1990)
KX60-B7 (KX60) (1991)
KX60-B8 (KX60) (1992)
KX60-B9 (KX60) (1993)
KX80-A1 (KX80) (1979)
KX80-A2 (KX80) (1980)
KX80-C1 (KX80) (1981)
KX80-C2 (KX80) (1982)
KX80-E1 (KX80) (1983)
KX80-E2 (KX80) (1984)
KX80-E3 (KX80) (1985)
KX80-G1 (KX80) (1986)
KX80-G2 (KX80) (1987)
KX80-J2 (Big Wheel) (1987)
KX80-L1 (KX80) (1988)
KX80-L2 (KX80) (1989)
KX80-L3 (KX80) (1990)
KX80-N1 (Big Wheel) (1988)
KX80-N2 (Big Wheel) (1989)
KX80-N3 (Big Wheel) (1990)
KX80-R1 (KX80) (1991)
KX80-R2 (KX80) (1992)
KX80-R3 (KX80) (1993)
KX80-R4 (KX80) (1994)
KX80-R5 (KX80) (1995)
KX80-R6 (KX80) (1996)
KX80-R7 (KX80) (1997)
KX80-T1 (Big Wheel) (1991)
KX80-T2 (Big Wheel) (1992)
KX80-T3 (Big Wheel) (1993)
KX80-T4 (Big Wheel) (1994)
KX80-W1 (KX80) (1998)
KX80-W2 (KX80) (1999)
KX80-W3 (KX80) (2000)
KXF250-A1 (Tecate 4) (1987)
KXF250-A2 (Tecate 4) (1988)
86 T3
84 T3
86 KX250
92049-1366 SEAL-OIL,MHSD8X18X10J this is the water pump seal I've replaced them on every motor I got.
Model (153):
KX100-D1 (KX100) (2001)
KX100-D2 (KX100) (2002)
KX100-D3 (KX100) (2003)
KX100-D4 (KX100) (2004)
KX100-D5 (KX100) (2005)
KX100D6F (KX100) (2006)
KX100D7F (KX100) (2007)
KX100D8F (KX100) (2008)
KX100D9F (KX100) (2009)
KX100D9FA (KX100 Monster Energy) (2009)
KX100DBF (KX100) (2011)
KX125-B1 (KX125) (1982)
KX125-B2 (KX125) (1983)
KX125-C1 (KX125) (1984)
KX125-J2 (KX125) (1993)
KX125-K1 (KX125) (1994)
KX125-K2 (KX125) (1995)
KX125-K3 (KX125) (1996)
KX125-K4 (KX125) (1997)
KX125-K5 (KX125) (1998)
KX125-L1 (KX125) (1999)
KX125-L2 (KX125) (2000)
KX125-L3 (KX125) (2001)
KX125-L4 (KX125) (2002)
KX125-M1 (KX125) (2003)
KX125-M2 (KX125) (2004)
KX125-M3 (KX125) (2005)
KX500-E10 (KX500) (1998)
KX500-E11 (KX500) (1999)
KX500-E12 (KX500) (2000)
KX500-E13 (KX500) (2001)
KX500-E14 (KX500) (2002)
KX500-E15 (KX500) (2003)
KX500-E16 (KX500) (2004)
KX500-E4 (KX500) (1992)
KX500-E5 (KX500) (1993)
KX500-E6 (KX500) (1994)
KX500-E7 (KX500) (1995)
KX500-E8 (KX500) (1996)
KX500-E9 (KX500) (1997)
KX65-A1 (KX65) (2000)
KX65-A2 (KX65) (2001)
KX65-A3 (KX65) (2002)
KX65-A4 (KX65) (2003)
KX65-A5 (KX65) (2004)
KX65-A6 (KX65) (2005)
KX65A6F (KX65) (2006)
KX65A7F (KX65) (2007)
KX65A8F (KX65) (2008)
KX65A9F (KX65) (2009)
KX65A9FA (KX65 Monster Energy) (2009)
KX65AAF (KX65 (CANADA ONLY)) (2010)
KX65ABF (KX65) (2011)
KX85-A1 (KX85) (2001)
KX85-A2 (KX85) (2002)
KX85-A3 (KX85) (2003)
KX85-A4 (KX85) (2004)
KX85-A5 (KX85) (2005)
KX85A6F (KX85) (2006)
KX85A7F (KX85) (2007)
KX85A8F (KX85) (2008)
KX85A9F (KX85) (2009)
KX85A9FA (KX85 Monster Energy) (2009)
KX85AAF (KX85) (2010)
KX85ABF (KX85) (2011)
86 T3
84 T3
86 KX250
CDI box for 1984 Tecate same as 1986-87 Tecate 3
The woodruff key for the flywheel is used in 768 Kawasaki models so its hard to go wrong here. Any KX, KDX200, Vulcan, Ninja, Lakota, Bayou, ect up to like 2006 or 2009.
86 T3
84 T3
86 KX250
92046-1128 BEARING-NEEDLE,TA2030 for the swingarm
Model (97):
KDX200-A3 (KDX200) (1985)
KEF300-A1 (Lakota 300) (1995)
KEF300-A2 (Lakota 300) (1996)
KEF300-A3 (Lakota 300) (1997)
KEF300-A4 (Lakota 300) (1998)
KEF300-A5 (Lakota 300) (1999)
KEF300-A6 (Lakota 300) (2000)
KEF300-B1 (Lakota Sport) (2001)
KEF300-B2 (Lakota Sport) (2002)
KEF300-B3 (Lakota Sport) (2003)
KLX250H6F (KLX250S) (2006)
KLX250H7F (KLX250S) (2007)
KLX250T9F (KLX250S) (2009)
KLX250TAF (KLX250S) (2010)
KLX250W9F (KLX250SF) (2009)
KLX250WAF (KLX250SF) (2010)
KSF250-A10 (Mojave 250) (1996)
KSF250-A11 (Mojave 250) (1997)
KSF250-A12 (Mojave 250) (1998)
KSF250-A13 (Mojave 250) (1999)
KSF250-A14 (Mojave 250) (2000)
KSF250-A15 (Mojave 250) (2001)
KSF250-A16 (Mojave 250) (2002)
KSF250-A17 (Mojave 250) (2003)
KSF250-A18 (KFX 250 Mojave) (2004)
KSF250-A3 (Mojave 250) (1989)
KSF250-A4 (Mojave 250) (1990)
KSF250-A5 (Mojave 250) (1991)
KSF250-A6 (Mojave 250) (1992)
KSF250-A7 (Mojave 250) (1993)
KSF250-A8 (Mojave 250) (1994)
KSF250-A9 (Mojave 250) (1995)
partzilla claims they have them for $12.00
the ta does not mean tapered bearings . . no mfg uses tapered bearings for swing arms . . those are for automotive wheel bearings and steering stem bearing upgrade from all balls etc.
ta series are small diameter rollers . . hk are larger diameter rollers.
There is no cross reference for a ta bearing . . if you need a ta bearing you must buy a ta bearing.
They are both drawn cup type bearings meaning they have an external shell/housing unlike a piston needle bearing which does not.
http://www.psbearings.com/html_news/...k-List-33.html
ta2030 - 20 long x 27 id x 30 od drawn cup bearing
Hk2030 - 20 long x 26 id x 30 od
86 T3
84 T3
86 KX250
92075-1153 DAMPER,SEAT 7
Model (45):
AR50-A1 (1982)
AR80-A1 (1982)
KL250-A3 (KLR250) (1980)
KL250-A4 (KLR250) (1981)
KL250-A5 (KLR250) (1982)
KL250-C1 (KLR250) (1983)
KL250-C2 (KLR250) (1984)
KRF750A8F (Teryx 750 4X4) (2008)
KRF750B8F (Teryx 750 4X4) (2008)
KRF750C8F (Teryx 750 4X4 LE) (2008)
KRF750D8F (Teryx 750 4X4 LE) (2008)
KRF750F8F (Teryx 750 4X4 NRA Outdoors) (2008)
KRF750G9F (Teryx 750 FI 4X4) (2009)
KRF750J9FA (Teryx 750 FI 4X4 LE) (2009)
KRF750K9F (Teryx 750 FI 4X4 LE) (2009)
KRF750L9F (Teryx 750 FI 4X4 LE Sport) (2009)
KRF750L9FA (Teryx 750 FI 4X4 LE Sport Monster Energy) (2009)
KRF750M9F (Teryx 750 FI 4X4 NRA Outdoors) (2009)
KRF750NAF (Teryx 750 FI 4X4) (2010)
KRF750NBF (Teryx 750 FI 4X4) (2011)
KRF750PAF (Teryx 750 FI 4X4 LE) (2010)
KRF750PBF (Teryx 750 FI 4X4 LE) (2011)
KRF750RAF (Teryx 750 FI 4X4 LE) (2010)
KRF750RBF (Teryx 750 FI 4X4 LE) (2011)
KRF750SAF (Teryx 750 FI 4X4 Sport) (2010)
KRF750SAFA (Teryx 750 FI 4X4 Sport) (2010)
KRF750SBF (Teryx 750 FI 4X4 Sport) (2011)
KRF750SBFA (Teryx 750 FI 4X4 Sport) (2011)
KRF750TAF (Teryx 750 FI 4X4 SGO) (2010)
KZ1000-K1 (LTD) (1981)
KZ1000-K2 (LTD) (1982)
KZ1000-M1 (CSR) (1981)
KZ1000-M2 (CSR) (1982)
KZ250-W1 (LTD Belt) (1983)
KZ550-F1 (Spectre) (1983)
KZ550-F2 (LTD Shaft) (1984)
KZ550-H1 (GPz) (1982)
KZ550-H2 (GPz) (1983)
KZ550-M1 (LTD Shaft) (1983)
ZL900-A1 (Eliminator) (1985)
ZL900-A2 (Eliminator) (1986)
86 T3
84 T3
86 KX250
Thanks a lot Dudeson's, thats quite a bit of info.
I notice one this info the rod parts appear to be the same for 1974-1997 even though Kawasaki says the rod kit doesn't. Does Rod rebuild kit work for all Kx250 1978-1997-2004? The KX250 70mm piston was 1978-1986. So the bore and stroke changed in 1987 on KX250 and on KFX250 Tecate 4. So are rods different lengths or is it just the piston pin location is different to change the stroke?
Part Number 13044-5056
Description: SET-CONNECTING ROD
Package Quantity: 1
Item Status Code: Active limited quantity
Model (12):
13044-5042 SET-CONNECTING ROD includes washers, big end bearing, and pin
13034-1060 BEARING-BIG END,H24X3
Model (6):
dont know what is still available from Kawasaki but the rod should be easy to find
13035-034 PIN,CRANK
Model (40):
KDX250-A1 (KDX250) (1980)
KDX250-B1 (KDX250) (1981)
KDX250-B2 (KDX250) (1982)
KDX250-B3 (KDX250) (1983)
KDX250- (KDX250) (1984)
KT250-A (1975)
KT250-A2 (Trial) (1976)
KX250 (1974)
KX250-A (1975)
KX250-A3 (1976)
KX250-A4 (1978)
KX250-A5 (1979)
KX250-A6 (KX250) (1980)
KX250-A7 (KX250) (1981)
KX250-B1 (KX250) (1982)
92026-1241 SPACER (Washer)
Model (47):
F11 (1973)
F11-A (1974)
F11-B (1975)
F11M (1973)
KE250-B1 (1977)
KE250-B2 (1978)
KE250-B3 (1979)
KT250-A (1975)
KX250 (1974)
KX250-A (1975)
KX250-A3 (1976)
KX250-A4 (1978)
KX250-A5 (1979)
86 T3
84 T3
86 KX250
Found out another fuel petcock that worked very slick. Fit perfect and took about 5 minutes to install. Nearly the same as the banshee (2GU) and 400 bigbear (2HR). It's a big bear 250, 3JN (-24500-02. All have same last 7 digits). It has a outflow to the front. Stuck it on today and really like it. Oh, and it's the cheapest for some reason- $16.95 + $2.75 shipping. Banshee at my dealership here was $36 and a week and a half out, ridiculous, got this one in 3 days for half the price, & the same thing.
Last edited by hang&rattle; 11-07-2010 at 11:12 AM. Reason: Missed a digit on the final 2 #'s, it's '02' not '00'. And the 400 Big Bear is '2HR'. Sorry guys!
