You should be running a 460-480 main jet with that set-up. Needle clip in the middle position,and a stock pilot jet.
You shoud be running around 32-1 up to 40-1 on your mix.
Make sure your air filter isnt over oiled,and check your coil and plug wire and cap.Those are some what a problem on the Z.The case would crack and arch out on the frame.They will idle good and pull ok till about 1/4 throttle, then they act like a rev limiter is on, if the coil is bad.
Welcome to the site.
Ohh and this forum is for racing,and planning for races.
Tech questions will get more input in Trikesylvania.
Proudly NOT a member of
"Team on the Teat"
