Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 46 to 60 of 79
Thread: 1986 Honda 250R build*finished*
  1. #46
    Las Vegas, NV.
    2,454
    Looking very nice!
  2. #47
    Apr 2012
    USA
    4,114
    That harness looks a little different from stock =). Looks like it fits the machine well. Looks like it won't be long and it will be ready to fire up.
  3. #48
    Sulphur Springs,Texas
    1,005
    Another thank you to member ps2fixer for his awesome wiring harness for the 86 250r. It looks great! Thanks again Cory!
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
  4. #49
    Apr 2012
    USA
    4,114
    Looks like I used looks like too much lol. Not a problem on the harness, glad you like it.
  5. #50
    Slidell, LA
    4,737
    That bike looks like it’s ready for an extra special bullet?
  6. #51
    1,005
    Very close to a VP bullet!
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
  7. #52
    Feb 2007
    ontario canada
    I'm so glad I found this thread. I'm rebuilding my 85 250r right now. Your way ahead of me but your thread is so informative!!!! Saved me so many head aches and energized me to work on it more. Got my swing arm done the other day using same paint as you.
    Thanks again!
    Sent from my SM-G960W using Tapatalk
  8. #53
    1,005
    after seeing ironchop's post on putting the rings in the air box I went the same route. I picked up a couple rings from bdtmotorsports.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
  9. #54
    1,005
    I got a repop front brake line off eBay. I know from onetrackmind's build that the repop do not build good pressure. I learned of HoseFast a hyrualic repair company from onetrackmind a year or so ago when I needed to get a 350x repop front brake line fixed with similar symptoms as his 250r line. I got my 250r repop brake line in yesterday and went to HoseFast today to have an new braided line put in and new banjo eye fittings while keeping the look of the repop.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
  10. #55
    1,005
    picked up some VP C-12 for the engine.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
  11. #56
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by Hondatcs View Post
    Why do you want to run that?
  12. #57
    Slidell, LA
    4,737
    Because I built the engine to run that.
  13. #58
    Jan 2013
    minnesota
    5,911
    If he can get away with rm2 109 octane, the engine will make more power with VP MS109 and it is only a few dollars more.
  14. #59
    Slidell, LA
    4,737
    Thanks for your input.
  15. #60
    1,005
    Motor time
    A HUGE Thank you to Yaeger Performance Machines for building this motor! It turned out amazing! Here are things that YPM did to it.
    1.85 lower end
    2.Transmission gears back cut and polished
    3.New Pro X Rod std length, crank tins welded, crank balanced
    4.Paul Turner Eliminator Cylinder, new LA sleeve with std bore, ported by Duncan Racing.
    5.Squish set up to run 110 octane.
    6.All new OEM bearings and gaskets
    7.Counter Balancer Rebuilt.
    8.Cases, Cylinder, and Head powder-coated with a custom ppg darkshot silver.
    9.Vforce 3 Reeds.
    10.38mm Air Striker
    11.O-ringed exhaust flange.
    Attached Thumbnails Attached Thumbnails IMG_0492.jpg   IMG_0493.jpg   IMG_0495.jpg   IMG_0496.jpg   IMG_0497.jpg   IMG_0498.jpg
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
