+ Reply to Thread
Page 2 of 2
FirstFirst 1 2
Results 16 to 22 of 22
Thread: Troll's Trike.....Done
  1. Join Date
    Pennsylvania
    Posts
    1,056
    Share
    Quote Originally Posted by 350x'inNY
    Sweet..... I wonder if we could ever talk OCC, UniqueWhips or that show "Build or Bust" to make offroad trike creations? You'd be a shoe in!
    Bruce
    I wish overhaulin would come steal my 200s and put a nicholson and all that jazz on it lol
  2. Join Date
    Pennsylvania
    Posts
    1,056
    Share
    Thats one nice air cooled right there!
  3. Join Date
    Feb 2003
    Posts
    403
    Share
    That thing is amazing, but I really don't like the bars at all. You should swap them out with some nice renthals. Great looking R.
    Owner of
    '98 klx 300r
    '85 250sx
    '82 185s
  4. Join Date
    Apr 2003
    Posts
    396
    Share
    Thanks for the replys. Heres a little revival write-up.
    84' 250r project bought for $150 and a set of paddles. Pic looks better than it was. Just rode hard and not alot of tlc.
    http://www.3wheelerworldforums.com/s...ight=westcoast
    Basicly started with the rear, found out the trike came with a westcoast swingarm, aftermarket spring and extended dura-blue axle.
    Here's a after pic. Had to machine the axle and build-up the axle bearing surface. Then polished and clear-coated it as well as the swing-arm.
    Had to remove and lathe out the swinger bearings. Then dads got a set for me. Also installed new pads, sprocket, ect..
    Mockup;
    Installing later model fenders. Had to graph two seats together to fit the stock tank. Then redo the mount pads and latch.
    Then started sand-blasting the frame.
    After 300 lbs of sand the frame got painted. Now for the fun.
    Going together;
    Got the swinger on, lubed the bearings and pivots with full syn grease. Then there was a set of tapered steering head bearing and got the same.
    Spent a little time polishing the forks and tripples
    Got a little more done. The front hub got some work, then playing around with the headlight. Got the twist throttle polished, and pipe bbq painted. Spent some time finishing the seat, molded the foam and attached the material.
    It's on all three now.
    All the aluminum was polished, widened 200s bars with twist throttle and new grips, new fork seals, brake pads, wheel bearings, ect...
    Rebuilt the westcoast swingarm and durablue wide axle. Modded 86' 350x rear wheels. The airbox got a new lid and now has clear sides. Just added double wide footpegs.
    Made a grab bar, revived the silenser and pipe, and added a electronic speedometer and 250r emblem.
    Bent up some diamond plate fresh air intakes, polished the stainless rotors.
    Too much fun.
    ..........................Engine.................. ..
    Bored .020 over and new wisieco piston, boysen duel stage reeds, 32mm mikuni carb and CT expansion chamber.
    http://www.3wheelerworldforums.com/s...ighlight=bored
    Finally got the engine in, had to use a different rear sprocket for the chain to fit.
    Also made a tool can out of stainless. Love the double wide pegs. Basicly just waiting for the tank to get painted..
    Well thanks again for your replies. Oh, the bars were done on the last project. Just had to change up a bit this time............lol.
    84'R pic page; http://magoos.wheatfarm.com/pictures/index.php
  5. Join Date
    Jan 2005
    Spruce Head Island, Maine
    Posts
    893
    Share
    it may be just me but i like the bars like that, makes it look different.
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
  6. Join Date
    Jan 2005
    Posts
    893
    Share
    almost as bad looking before pics as the 200x i want to get and restore, basicall a frame, rear end and front forks.
    Past Rides:
  7. Join Date
    springville, PA
    Posts
    6,023
    Share
    If there is any trike nicer than that 250r, then it is your 350x. I love the color scheme on that thing
    Nate
    "I cant catch Bryan Raffa, cant catch 'em! Bryan Raffa is just too fast! If by some space time paradox Bryan Raffa was to go back in time and race Bryan Raffa, Bryan Raffa would win!!!"
+ Reply to Thread
Bookmarks
