Most modern worked 250's rev over 11K rpm. 500's though are hanging there tongue out around 8k.
4 Strokes are NOT the wave of the future!
a wise old racer told me years ago you just hold it wide open till you see god.......then shift
lol
WWW.HREATV.COM
lol....glad you guys liked it
he had it painted on his trailer after we all started useing it.
WWW.HREATV.COM
I know typical 2 strokes rev like crazy, somewhere in the 9 - 12 thousand range. Just my guess...
the 2 strokes alldepend on porttimign ignition timign bore / stroke ratio, carburation , somany variables i was messign aroudn with my drag bike and advanced the timign 7 degrees and gained abotu 3k on top but mad eit almost impossibel to start by kicking itand refused to idle. but i have even seen twin cylinder2 strokes rev as high as almosy 17-20 k range and as far as the 350x and similar 4 strokes they did not have a preset rev limiter liek moden thumpers but they woudl rev out tillthe vlaves started floating( i am knowm for it)
I was thinkin the same thing because my R screams to bloody hell, although I know when to stop, but i rode both my friends slightly modified Rs and they didn't seem to rev near as high you could dang near hold em wide open and they wouldnt scream as loud as mine and mines still has a ways to go, for certain it would blow up if you wanted it too. My brothers 200s floats the valves all the time of course he rides it like theres no tomorrow.
'81 ATC 250r: IMS tank,Uni pod filter,Keihin PJ flat 38mm,Boyesen Pro series reeds,reed spacer w/ boost bottle,milled head,bored(.080),ported,machined CR exhaust flange,and Mugen pipe.PK +3 swingarm,2+2 axle,ITP rims,and 200X fork swap w/ polished tree.
'03 CR 250R: FMF fatty w/shorty, Pro Taper top clamp
'85 ATC 70: 88kit, race cam, ported head, 5 angle valve job, cobra pipe, 20mm carb...
'73 ATC 70 roller, '80 ATC 110, '86 ATC 125m, '81 XL 500s, '71 Z50, '76 Z50 W/ Lifan 125
'84 Tecate 3
So, brapp brought it around to the real heart of the matter. The term "rev limit" and "red line" are from the four stroke world and they indicate the point where you need to stop reving before you start to damage the valve springs. The question that was being asked was more along the lines of "how high do they rev" not "what's the mechanical limit" so the answer for 2-strokes is hard to nail down. It's going to be different for various builds even of the same model trike. With the four strokes there's a hard limit, though and it's determined by the strength of the valve springs. I would love to know what that number actually is for a 350x so that I could look for some springs from some other application that could take the abuse of a higher rev. I think the 350 leaves a lot of power on the table but I don't want to destroy my valve springs to find out.
Sure wish they'd come with a tach.
all you need is some r&d aftermarket springs
my 350x has a a high rev cam with a old set of r&d springs and it will rev till the ignition gives out (not a rev limiter)
now, from way back in the day i seem to remeber that a 350x ignition is good till about 10,000 rpm
my 110 is the same way.....huge cam titanium retainers and r&d springs.....revs to the moon (or untill you see god.....lol)
if a 4 stroke is built right you can rev them past the power band or untill the ignition gives out
WWW.HREATV.COM
yes swiggin is right but with a stock motor it will float the valvs unless modified to resist the floating feelign until the ignition can not keep up. and with a 2 or 4 stroke trike they will rev until they can not support the amount fo fuel and air or they blow apart
I know this is an old post, but I thought I should tie up a loose end here.
I don't have any specifics with me at the moment, but I know there is a math formula you can use to figure your rpm's.
For this you have to know the Primary Gear Ratio, Gear Ratios for each gear (which I can post later on if anybody would be interested), Front sprocket size, rear sprocket size, tire height...
If you know your maximum speed in a given gear, then you can calculate your RPM's based on your gear ratio's, tire height, etc...
Or if math isn't suitable, install a tachometer.
-Rustytinhorn
A few wheelers, + an
'73 Honda 49cc Mini Trail
'85 200 Big WHEEL
"Despite the cost of living, its still popular."
