Let me know any suggestions or ideas, I'm all for building adapters to make old harnesses be able to plug into newer parts.
________________________________________________
Color Key:
Green = I can reproduce 100% new parts
Red = I need donor harness to use the plastic shell of connector(s) that I can't source new
Yellow = Requesting photos, if you have the part, please pm or post clear high quality photos
KAWASAKI
Tecate 1984-1985 - Wire Harness
YAMAHA
YTZ250 (Tri-Z) 1985-1986 - Wire Harness
HONDA
ATC70 All Years - Headlight/Tail Light Wire Kit - Need a set to copy.
ATC90/US90 All Years Wire Harness - Based on my research, all of the 90cc Honda 3 wheelers used the same harness, can anyone validate? Harness does not have the round rubber grommet for the tail light wire.
ATC110 1979-1980 - Wire Harness
ATC110 1981 - Wire Harness - Can't locate quality photos, could someone post/pm me some of the connector ends? I'm 95% sure I can make it based on other years.
ATC110 1982 - Wire Harness - Have not attempted to locate new frame grommets yet
ATC110 1983 - Wire Harness - Have not attempted to locate new frame grommets yet
ATC110 1984 - Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC110 1985 - Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC125M 1984 - Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC125M 1985 - Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC125M 1986-1987 - Wire Harness - I couldn't see inside the black rubber boot very well, could use photos of that area to validate
ATC185S 1980-1981 + ATC200 1981 - Wire Harness
ATC185S 1982 + ATC200 1982 - Wire Harness
ATC185S 1983 + ATC200 1983 - Wire Harness
ATC200 1981 - Wire Harness - See ATC185S 1980-1981
ATC200 1982 - Wire Harness - See ATC185S 1982
ATC200 1983 - Wire Harness - See ATC185S 1983
ATC200E 1982 - Wire Harness
ATC200E 1983 - Wire Harness
ATC200M 1984 - Wire Harness - Unable to locate new 6 pin round CDI Plugs - There are 3 part numbers for this year, not sure why, one interchanges with 85
ATC200M 1985 - Wire Harness - Unable to locate new 6 pin round CDI Plugs - There are 2 part numbers for this year, one interchanges with 84
ATC200ES 1984 - Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC200ES 1984 - Keyed Ignition - Ignition switch sourced from china, fairly good quality wires are replaced with GXL wire
ATC200S 1984 - Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC200S 1985 - Wire Harness - Unable to locate new 6 pin round CDI Plugs - There is 2 part numbers for this year, maybe the 2 plug CDI was introduced this year, if so it should be the same as an 86.
ATC200S 1986 - Wire Harness - Must have 2 plug CDI (4+2)
ATC200X 1983 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC200X 1984-1985 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC200X 1986 Wire Harness
ATC200X 1987 Wire Harness - Can't locate quality photos, could someone post/pm me some of the connector ends?
ATC250ES 1985 Wire Harness - Unable to locate new pulser connectors and 6 pin round CDI Plugs
ATC250ES 1986 Wire Harness - Unable to locate new pulser connectors
ATC250ES 1987 Wire Harness - Unable to locate new pulser connectors
ATC250ES 1985-1987 + TRX350D 87-89 - Sub Wire Harness for Headlight bulb
ATC250ES 1985-1987 - Headlight Wire Cord - $35 (no gromets, and I'd like to find a thicker tubing to use)
ATC250R 1982 Wire Harness (should fit 81)
ATC250R 1983 Wire Harness
ATC250R 1984 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC250R 1985 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC250R 1986 Wire Harness - Haven't calculated cost yet (check and make sure you have the 4+2 cdi connectors).
ATC250SX 1985 Wire Harness - Unable to locate new pulser connectors and 6 pin round CDI Plugs
ATC250SX 1986-1987 Wire Harness - Unable to locate new pulser connectors
ATC250SX 1985-1987Sub Wire Harness for Headlight bulb
ATC350X 1985-1986 - Wire Harness
ATC350X 1985-1986 - Headlight Socket Pig Tails (Pair) Sockets are sourced from Honda, so very good quality!
