Thread: Honda atc 70 chain tensioner upgrade diy
    oldoo's Avatar
    oldoo is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2017
    Australia
    155
    So today after work I decided to muck around with my old flogged out chain tensioner.
    So... I drilled out the old tensioner sprocket and bolted on a rubber roller.
    I have two choices to either bend the plate to allow the bolt to clear, or grind back and weld the bolt.
    oldoo's Avatar
    May 2017
    Australia
    155
    Welded it up, looks Schmick. I just need to tidy it up.
    Jun 2009
    Leander TX
    2,219
    Nice.
    When I do mine like that, I drill & tap the plate, screw the bolt in, grind to length.
    Then take it apart and put back together with loctite.
    oldoo's Avatar
    May 2017
    Australia
    155
    Quote Originally Posted by jb2wheels View Post
    Nice.
    Yeah nice, that came to mind too and would also work well.
    Cold Lake, Alberta, Canada
    3,001
    Does this upgrade quite down the usual noises the stock tensioners make?
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    1978 Honda XL75
    oldoo's Avatar
    May 2017
    Australia
    155
    I'll let you know once the project is done
    na
    5,702
    I have been just using the plastic roller with needed washers- bolts and spacer and bolting it to the slotted groove and loosen and adjust as needed. 5 years still going..12 bucks and 20 minutes
    Proudly NOT a member of
    "Team on the Teat"
