broke off the cheap plastic petcock and hoping someone has found a better option? Thinking I might be able to thread a couple of brass npt fittings in there as well.
I have read the reviews on those tanks, and that is a major failure point on them.
It may be possible to heat the tank (empty and washed) just enough to soften the plastic and then thread a brass bung into place.
then you would have a brass fitting to work with after the plastic has cooled.
I have had very good luck with a heat gun on Honda plastic fenders and PVC pipe.
MrC.
Someone needs to make them out of billet aluminum . I would be in for a half dozen .
They all fail eventually , big problem .
Yep that’s it , simple part .
Bolts to the bottom of the tank and two fat o-rings seal it .
Problem is , the plastic warps over time and the o-rings can’t seal tightly , or it just cracks near the nipples .
brand new tank and broke both nipples broke off while removing the fuel line.. Anyone try one of the aftermarket petcocks?
https://clarkemfg.com/product-catego...arket-petcock/
I don’t see how that style would even work when the original style has 2 holes into the fuel tank for on and reserve .
https://clarkemfg.com/catalog/motorc...90-02-grooved/
I used that petcock on a early 200X Clarke tank. It hasn't leaked in 5 years that I'm aware of.
That tank only had one hole though, not like the 70 tank
Your results may vary, of course. I block sanded the mating surface section of the X tank to make sure it would seal
I have some aluminum tubing coming from amazon and am going to make my own. I will post pics on how it turns out.
