Page 1 of 7 1 2 3 ... LastLast
Results 1 to 15 of 95
Thread: brake caliper swaps for 83-85 200x's
    Sep 2003
    Elizabethtown PA
    1,581
    i bought a nice 85 200x off ebay for $300 that runs great but had no rear caliper and the front was bleed rite and held the bike when pushing on it in the garage. but i found out on the test drive that it di not stop the trike when riding it. piston was partually sticking and i almost hit a tree.
    i have piles off 200x parts and all the rear caliper i have the pistons are stcuk bad. so i was searching on ebay for calipers and found out that CR 80 front caliper are close to the same for the back of a 200x. they bolt the exact same to the 200x bracket you attach to the swingarm. the rotors to big for the cr 80 bracket. i got one from a 2006 cr80 that was being parted out for $22. back into the 80's even the cr80 uses the exact same caliper
    after finding that out i went searching under every type of dirt bike caliper to see what would fit since on the front of a 200x since the slider and pin are switched. walla a 2000 kx 80 rear caliper bolts rite up to the front mounting bracket that attaches to the fork. i chanced it and bid on it and won it for the starting bid of $5. not sure what other years are the same.
    just letting you know to help out some fellow 200x owners out.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Sep 2003
    Elizabethtown PA
    1,581
    here is some pics of the front caliper swap i did. the 1st picture is a side by side with the right one being the 2000 kx80 caliper on 200x bracket. it bolts rite up
    Attached Thumbnails Attached Thumbnails PIC00001.JPG   PIC00005.JPG   PIC00006.JPG
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Sep 2003
    Elizabethtown PA
    1,581
    heres a picture of the rear caliper swap. it's a 2006 cr80 caliper on a 200x bracket. it bolts rite up also the caliper only sold for $26
    the second is a master cylinder from a 2002 cr80. i got the whole front brake setup for $23.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Willamstown PA
    5,823
    jason,
    a member ask me this info and i found the right years that fit for the KX80 calipers:
    "ok man heres your info on the KX80 rear calipers. the caliper is the same from 1987-2007 but changes part numbers per each year it was restyled.
    heres the breakdown.
    KX80 1987-1997 (bikebandits part number for the caliper assy) 591700-001
    KX80 1998-2000 (bikebandits part number for the caliper assy) 591608-001
    KX85 2001-2003 (bikebandits part number for the caliper assy) 1480316-001
    KX85 2004-2007 (bikebandits part number for the caliper assy) 1822434-001
    i belive the manufactures are doing now days is every times somthing is restyled some what they give the parts a new part number so there is no confustion on what year parts fit. alot of times these parts are 100% the same as other parts reason i say so is because my wifes 89 cr80 was running a 02 cluch cover under a dif part number then 89 but it was 100% the same, just not painted black.
    there were may style changes in the kx80 line up from 87-97 but parts didnt change, in 98 the style changed, it was gas tank, front number plate and number plates, thats reall it! in 01 it just got 5cc more to make it a 85, nothing else changes really. in 04 is of a left radiator shroud and thats about it, style has been the same since 98.
    hope that helps. this sould be posted in jasons atc200x thread also. maybe ill do that too."
    aaron
    the cr80 front calipers are the same from 1986-2002 after that cr85 2003-07 is a dif part number. the CRF150R may use the same front and rear calipers the old CR85did. hope this helps everyone.
    Sep 2003
    Elizabethtown PA
    1,581
    actually i seen no difference in the 2002 cr80 caliper i have laying on the shelf from the 2006 cr85 one i used on my 200x.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Jun 2006
    Willow, Alaska
    1,337
    So does the cr80 caliper bolt right on, or what do you have to do to make it fit? Did you just use the 200x bracket instead of the cr80 bracket?
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    Jul 2006
    western ny
    3,366
    also do we need a smaller roder ? or can we use the stock x one ?
    GIT IT RAAAGGGGG !!!!
    Sep 2003
    Elizabethtown PA
    1,581
    all i did was use the 200x bracket and just bolted the cr80 caliper to it. it fits rite on
    i used the 200x rotor when i installed it like mentioned above
    it's been working awesome the last couple times i rode
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Jun 2006
    Willow, Alaska
    1,337
    Thanks man that cleared things up.
    -Nick
    Aug 2006
    Arlington, Wa
    1,027
    bump to a very good thread
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    85' YTM 225DX (sweetie)
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    gizmo_22's Avatar
    gizmo_22 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2006
    Bathurst NB Canada
    305
    any chance of maybe a sticky on this one guys? Its good info for a common problem.
    Sep 2003
    Elizabethtown PA
    1,581
    bringing this one to the top to get noticed to help people out
    NOTICE i just found out also the this swap will work on a trx250x or 300ex quad also. a 350x will work also.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Nov 2008
    BR
    3
    i have my rear brake is out my 85 200x... so what works!
    Dec 2005
    Wisconsin
    1,141
    Thank you Jason for the great info here. I installed a 2003 CR85 front caliper on the rear of my 85 200X. It was as simple as switching the mount plate for the caliper, bolt it up and bleed out the air. Now I'm rockin with a NEW caliper and one that doesn't have all the extra crap for the parking brake.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by WIkid500 View Post
    no problem glad to see it worked out good for you. It;s a lot less of a pain then rebiulding your old crusty original one
    one of the ones i bought was from a 2002 cr80 and the sliders were stuck already. i just used it on a 1993 300ex a have thats getting a 350x motor in it.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
