Thread: What year Tecate Motor is mine? "Clutch problems"
    Apr 2003
    Central New York
    1,860
    The # on the motor is
    KHIKX250CE005641
    any idea on the year of this thing?
    Got a weird clutch problem and am wondering if its the pushrod or something. I guess the 84 is different than the 85 and I dont know what im using. Need specs on the lengths of the pushrods for each year. Any difference in Clutch Baskets for the 84 or 85?
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    hadar's Avatar
    Rock Island IL
    699
    I think you can tell by the shift shaft assbly. According to Kawasaki.com owner info the 84 uses a shaft that is shaped differently. That's the only difference between the two I know of. I have only worked on 84 engines so I'm not 100% But I do remember ordering a shift shaft for an 85 and it turned out to be that wrong one.
    Oct 2005
    saratoga, ny
    2,819
    the manny says that the pushrod is 1mm longer on the 85 then the 84 so they cant be interchanged. i believe one way of telling is by looking at the grooves in the clutch discs. the 84's all go the same direction and angle, the 85's are at different angles...if this helps. the clutch push rod, clutch release, and clutch springs do not interchange. hope this helps gary.
    Apr 2003
    Central New York
    1,860
    Thx
    I appreciate the info. We keep going to finish a part of the project and it just keeps getting jammed up. Do you have the length of the 84 pushrod? I just dont see how one mm will make a difference. But who knows.
    84-85 Custom Tecate
    Jan 2005
    RI
    2,530
    grind one mm off of that and youre set
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2003
    Central New York
    1,860
    clutch plates
    Does anyone know if the Barnett Clutch plates are thicker than stock? Or different widths for 84 to 85? Thx
    84-85 Custom Tecate
