Thread: 350x front sprocket
    May 2009
    S.E. Michigan
    1,251
    350x front sprocket
    On my last ride with the 350x, I had to do an emergency front sprocket replacement (don't ask). Anyway, it was a Saturday and I wanted to ride and all the honda shop had was a front sprocket for a 200x (according to the label). The splines were right, it was 13 teeth (stock) and the chain pitch was right. SOLD! For reference, it was a Moose JTF1352-13.
    However, my question is concerning the thickness of the sprocket. The new sprocket was thinner than the original. The old sprocket had extra material on the side to make it thicker. I'm guessing this is to handle the extra torque of the bigger motor on the 350x.
    Should I order the proper 350x "Official" front sprocket (now that I'm not in a time crunch), or just run the Moose? It worked fine for the weekend, but I'm worried about long term damage to the splines on the output shaft due to not enough material engagement between the sprocket and shaft.
    And advice or opinions would be appreciated!
    Apr 2006
    Crestview, Florida
    2,429
    I'd get the right one. The 350x's are known for stripping the countershaft.
    Rides
    85 ATC350X
    85 ATC200X
    PA
    3,515
    the sunstar trx 250r are the front sprockets to use on a 350x.
    they are the thickest made (2 steps) and you can go up to15t.
    WWW.HREATV.COM
    Feb 2008
    Pennsylvania
    2,305
    I think you can use the front sprockets for the Honda 300ex also.
    '86 Honda Big Red 250es
    '85 Honda 250sx
    '87 Honda 250sx
    '85 Honda Atc 70
    '83 Honda Atc 70
    '00 Honda Trx 90 (sons ride)
    atc70/110
    May 2009
    S.E. Michigan
    1,251
    Awesome. Thanks for the information guys. I'm gonna order a new one for sure now.
