Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: Bought a 1984 200ES Big Red for $100! No Key? No Manual?
    Minnesota
    31
    Thanks much for the manuals! I'll post some pics when I get a chance.
    Minnesota
    31
    Well I just finshed replacing the stopper paw on my 110 so on to the Big Red.
    I can't seem to get the shifter into neutral. It will go between a couple gears but not neutral. I haven't tried to start it yet because I have a new key switch on the way but will it even start in gear? Is there a way to trick it into thinking it is in neutral just to see if I can get it started?
    Minnesota
    31
    Update on my $100 Big Red-
    Haven't had much time lately so been doing what I can when I can. Started off by replacing the key ignition. I think it had been siting so long things were kinda sticky so I rocked it back and forth long enough to get it into neutral. Hit the start button and it turned over but no fire. Shot some starter fluid and a new plug and it ran for a couple seconds. Now that I know it will run I changed out all fluids. Tried to fire again and noticed exhaust coming out of the side of the header pipe connection. I took the two bolts out to check the spark arrestor and it basicly fell off. The exhaust was so plugged up it wouldn't stay running. After cuttin off the end of the canister and clearing the exhaust it would run but it was obvious it needed a carb rebuild. Tonight I finished the carb, put in fresh fuel and it runs like a champ. One problem - when it sits not running fuel drips out of the hose at the bottom of the bowl. Is the float sticking open? What did I do wrong during the rebuild?
    Nov 2008
    ontario
    1,055
    i think the new float valve needs to get worked into the seat imo, can we get some pics?
    proud owner of a trx300ex quad and an 85 atc 70
    Apr 2009
    Parker, CO
    607
    nice work mate, glad to hear you got it fixed up. few things as gratifying as bringing a bike back to life!
    greythorn3's Avatar
    greythorn3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2007
    ALASKA
    302
    man i want one of them big reds with reverse!!!
    1985 big red 250es working good. 1983 200e waiting for new crank and rod. 200x project looking needing everything.
    Mar 2007
    Texas
    5,045
    in my sig is a link to a manual site. free downloads.
    ________________
    https://www.mikesatvfix.com
