Thread: Atc200es rear axle problem!
    Quebec, Canada
    3
    Hi i'm new over here!!
    First of all please apologize my poor english!! i'm trying my best!! :P
    I received a few day ago a Honda atc200es for free!!!
    the only problem is that the rear diff is in part...the rear axle is broken
    so i bought a new axle
    but now I just find out that the rear brake pad and drum are missing, and that the ring gears solder on the axle shaft...(picture for more detail)
    And I would like to know how much a gasket set is for the rear axle...and if someone have the bearing spec thanks!
    Thanks!!
    here the pics of the old broken axle
    http://g.imagehost.org/view/0735/P7120178
    http://g.imagehost.org/view/0175/P7120177
    here is my new shaft
    http://g.imagehost.org/view/0683/P7120180
    Apr 2009
    Parker, CO
    607
    Im not seeing any pics
    Quebec, Canada
    3
    I thinks it's working now...sorry!!!
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Welcome on the boards! Where are you from? I'm from Québec too, maybe I can help you.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Mar 2007
    Texas
    5,045
    something doesn;t look right wit hte ring gear. are you sure it's for your 200es?
    trypically the axle will slide through the differential and the ring gear is attached to the diff. as seen here.
    http://www.bikebandit.com/houseofmot...s-1984/o/m1891
    that differential is totally different. i think it's the wrong diff ro one for some otehr vehical that someone just stuck there.
    Here is one on ebay compelete that you can bolt on and use.
    http://cgi.ebay.com/ebaymotors/1984-...Q5fAccessories
    ________________
    https://www.mikesatvfix.com
    Quebec, Canada
    3
    Yes i'm from Quebec!!, Laval!! and finaly i went today to a machinist shop...he told me that the ring gear ''seat'' i solder on the shaft...so thant why it's look different...
    Fanaly i'm gonna buy another diff because i need like...a new ring gear seat a new ring gear, 2 new bearin, a new brake drum and shoe...so the easiest way to get it work is to buy another diff...I think i'm gonna go on Ebay...
    I also need new plastic fender and muffler...wath should I do...for plastic i'm thinking about doing home made fender in steel...for muffler again i think ebay would be my friend!!
    thanks!
