Results 1 to 15 of 17
Thread: UPDATE PICS ADDED Picked up a 85 125m
    Feb 2009
    Wisconsin
    521
    Picked up a 125m at a swap meet for $200. Its got pretty much brand new trail pros on it. I got it home today, fixed the pull start, cleaned the carb, changed the oil, fresh plug, fresh gas with sea foam. But I realized there was no key. Guy said it ran. So I pulled it once, and it fired right up.
    Runs good, all high and low gears work. Smokes like crazy! I sometimes here creaking while driving it? None of the lights work, Doesn't charge the battery, electric start doesn't work even with a good batt and jumping the solenoid. Pretty much the whole wiring harness is and spliced. But it runs, has brakes and a working kill switch.
    Anyone know where I can find a topend end for this bike? Ive searched ebay with no results.
    1985 Auto X lots of upgrades
    1982 Honda 185s 3inch wheel spacers, bassani exhaust
    2001 400ex
    1983 110
    Dec 2002
    deer park, texas
    2,336
    Quote Originally Posted by zppeacock View Post
    Its got pretty much brand new trail pros on it. .
    All trail pro's look new. They never wear. I swear in a million years they are going to dig up a YT and say " this is part of our history, but...... i wander when the new tires got put on it? "
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    louisiana
    1,499
    Feb 2009
    Wisconsin
    521
    Pictures coming, thanks for the link.
    The trail pros still have some of the hairs on them.
    2001 400ex
    1983 110
    6,797
    The creaking is probably loose wheel hubs .
    Trailpros Trailpros
    Feb 2009
    Wisconsin
    521
    I'll check out the hubs.
    Does anyone think that I could solve the smoking problem by a fresh set of rings?
    2001 400ex
    1983 110
    Feb 2009
    Wisconsin
    521
    anyone?
    2001 400ex
    1983 110
    chrisand4's Avatar
    chrisand4 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    NC
    250
    How much seafoam did you use with the gas?, one time a friend of mine put a whole can in his 4 wheeler and the thing smoked like crazy, just a thought, could be bad rings too though.
    Sep 2007
    California, USA about 50 miles north of sacremento
    976
    Wait Seafom + running enigne = Smoking. See you tube videos. Drain oil and see if it still smokes after a little while. Bad rings usually means lower compression. Done any compression tests?
    Feb 2009
    Wisconsin
    521
    Quote Originally Posted by TrailerRider View Post
    I know that seafom + running engine = smoke.
    It smoke before the seafom, its had 2 oil changes, carb clean, and a new plug. Its got low compression I can pull start it with 2 fingers. But it starts on the first pull ya honda!
    2001 400ex
    1983 110
    Sep 2007
    976
    I would pull the plug and put a little oil into the cylinder and see if the compression rises. With mine when I put the oil in the cylinder the pull got real hard like it should. This means likely the rings are shot. If the compression stays the same than maybe the valves need some love.
    Feb 2009
    Wisconsin
    521
    I tired that, it got a little more compression on the first pull, but then it was back down to what it always was. I dont have a compression tester but I looking to get one so I can get back to you guys with real numbers
    2001 400ex
    1983 110
    Sep 2007
    976
    Sounds like rings. Yeah the oil thing only works for 1 or 2 pulls then it will be back to the normal compression levels.. low. Get a tester and post the numbers. dratv sells the topend kits for your 125m. And much, much more. It's where most of us buy parts from. Have you grabbed a manual yet?
    Nov 2008
    ontario
    1,055
    if its smoking that bad the cylinder is prob scored too it will most likely need an oversized piston and a frsh bore
    proud owner of a trx300ex quad and an 85 atc 70
