do the 85-89 atc/trx250r motors have the same clutch baskets?
I'm curious of any differences myself..... Not just your basket
Not that this is helpful but:
I thought the years were "mostly" the same. The clutch update kit was on the long rod motors but still the same basket, No??
The 88/89 must have had a different crank and cylinder..... Or maybe the piston pin moved??
Did all 5 years have the same exact tranny??
Somebody educate me please![]()
Baskets are all the same. Cylinders all interchange, although the 88-89 have the better bridged intake. Cranks are different and so are the pistons. But all will interchange with all year 85-89 cases, just need the right combo of crank and piston. You can run a late style crank with a early style "short rod' piston providing you have a spacer plate.
okay, thanks for the help! buying some clutch discs right now, and some auctions put down 88-89 trx250r in the title.
here are some auctions:
http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
http://cgi.ebay.com/ebaymotors/PRO-R...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Clutc...Q5fAccessories
which one should I get?
http://www.3wheelerworldforums.com/s...+clutch+basket
There are some differences in the baskets.
Good info in this thread.
1981 ATC 70
1978 ATC 90
1985 ATC 250R![]()
www.cosmicquads.com
i have a trx clutch set inmy atc it uses an extra fiber and steel plate but the plates are thinner so its nothign to worry about. it works fine.
