Five Speed I'm pretty sure, but it didn't run so I didn't check it. My engine is definitely a 77 though. Look at the engine cases and such but the later model engines were different internally and externally. Also the yt engine has a "knockout" in the top of the engine cases and that is where the clutch release mechanism goes. You have to use the yt gears, but you have to use all the clutch parts from the it175 and I think you have to use the it main gearshaft as it is hollow and that is where part of the shifting mechanism runs. You can remove the oil pump and use the it175 clutch side cover buy you will have to close up the hole for the kicker gear. And it's way simpler to just use the recoil starter from the yt175. I think the only thing that you could use from the 80 it175 is the 6 petal reed cage. Other than that, I don't believe any of the other parts are compaatable.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
