Any tricks to remove it without the special tools. I used the penny trick to remove the pinion joint nut. But the bearing locknut won't budge. I've unstaked it. Help please.
I take it your not using an air impact?? I remove the cover, and with ring gear installed - I jam a penny in it, replace cover with 2 bolts and use an air gun to get it off.
Other than heat, I got nothing for ya!
RD81
http://www.3wheelerworldforums.com/s...t=92488&page=3
Scroll down to "THEFOX" post and you can see his tools or
http://www.3wheelerworldforums.com/s...t=92488&page=5
and scroll down to "RACERXXX" my post with a copy of my tools modeled after THEFOX's tools. I bought all my stuff at Home Depot for around $10 any ??? about the tools just ask. I also made bearing presses and seal installers. Measure the pipe fitting hex to fit inside your "lock nut" it's roughly 44 MM, but 1-3/4 hex is just oversize and you can use a right angle grinder to dress it to fit the 44 MM lock nut. Clear as mud right?
1985 Honda 125M (My first Trike--Still have it)
1986 Honda 250SX
1981 Honda 110
1982 Honda 110
1986 Yamaha YFM80 (Sons quad)
Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
1987 CR-80, 70's vintage XR75, RM 370
Dirtcrasher, I used your advice for the pinion joint nut and it worked great but this is for the bearing lock nut.
racerxxx, thanks for the pics of the tools. I'll be going to sutherlands tommorrow it looks like.
Thanks guys!!
