I have many 70cc motor in stock so I have try some modification.Here is what I do...Now the motor is in a 84 z50. Crankcase and gear are from a ct70.Clutch cover and clutch system from a xl70.Cylinder is from a stock ct70.Crank shaft is from a S65.The S65 crank have a mechanical timming advance to gain RPM.Head is from the S65.The S65 and ct70 is basically the same head,but the 65 combustion chamber is smaller than the 70,but with the same valve.The intake port give a lot better flow too.The cam is from a S65,same lift but A LOT more duration.And the piston....from a cb350F 1973,same dimension,same pin size but with a HIGHER piston top.I have grind the piston to clear valve (0.030" clearance) and clear the head.The piston dome is so high that I was affraid to hit the spark plug but it's ok.The carb is from a xl70 with a custom intake manifold.
I start it yesterday....motor run very strong,I hit 12000 rpm,and 180psi of compression...(130psi stock) The Z50 is now a beast.I now plan to do the same setup on my atc70.Everything look stock because all part I use are honda....
