Results 1 to 7 of 7
Thread: 84 honda atc200es big red idling problems
    howard, ohio`
    52
    Exclamation 84 honda atc200es big red idling problems
    Im having problems getting it to idle right, if i set it high enough it idles up and down like 1500-1700 but like sputters down to 400-600 but really fast it does all this, i cleaned the carb out when i pulled this thing out this summer (hasnt been run for a YEAR) could it be the pilot jet still clogged a little? i may run a small (i have a small set) drill bit through the holes?
    would running the smallest to normal size drillbit through the main jet and drilled it out like the smallest possible would it give me more top end power? or even low ?
    Apr 2009
    Parker, CO
    607
    Dont use a drill bit!! Use compressed air, carb cleaner, and maybe a piece from a wire brush. Good Luck.
    howard, ohio`
    52
    i have a drill bit set that is like .01mm and up like i could break em with my little finger but u suggest not to use them?
    Apr 2009
    Parker, CO
    607
    as a rule of thumb no, if you have something that small you should be ok.
    May 2009
    Brampton, ontario
    686
    if the bid is that small id just use it and some brake cleaner and use your fingers. dont use a drill.
    Looking for some smaller style tires like the r's have, just 2 back tires. pm please.
    howard, ohio`
    52
    yeah like i dunno where my dad got these but they are like the smallest **** i think ive ever seen but thanks, and do you think thats wats causing the horrible idle?
    howard, ohio`
    52
    And do you think a new spark plug and oil change is due? the spark plug im guessing is the original and omg on the oil lol! prolly 4+ years of use in that oil?
    what i think needs done
    -change oil
    -new spark plug
    -jets cleaned
    whats new
    -air filter
