I'm getting really frustrated, the first one went in no problem, but now that i have it on my rod, it does not want to go in ... i've got the circlip on my lip, but i'm about to throw it across the yard... any ideas?
aka pin lock
aka pin lock
practice makes perfect
WWW.HREATV.COM
I've never had much of a problem using a small straight screwdriver. I think they are harder to get out than to put in.
Rob
I put one end in the groove, use my thumb to hold it there.
Then I use a Test light probe in the little cut out on the piston, to help feed the other end in, while working my thumb around to guid the other half in the piston groove.
JUST... DONT BEND THE CIRCLIP.
Also a piece of duct tape on the started end of circlip taping it to the piston, helps keep that baby from shooting across the shop.
After you have done a hundred of them, they get easier...
But they still suck..LOL
Proudly NOT a member of
"Team on the Teat"
well i put it in, but the side of the piston got a little marred up ...
should be ok
cut off ice pick to get them out,, and a screwdriver with a tiny groove in it close to one side,,rag around the rod under the piston.
mosh thats a good idea with the tape .. had one fling the other day..
I put one end of the clip in the opening thats in the piston (not just the groove) and hold it with my thumb.
Then I PUSH the ring in with a small blunt object, I don't PRY it in, thats how you over extend and bend the clip![]()
SAFETY GLASSES! Won't help get it in but saves your eyes when they go winging across the shop.
__________________
'85 ATC250R
.030 Over Wiseco
FMF Pipe/Answer silencer
36PJ Keihin
K&N
Boyesen reeds
Magura hydraulic clutch
Roost Boost
MSR bars
OMF swingarm skid
ITP Beadlocks
Three Wheelin' Since '84
Yeah i just used a precision screwdriver, one of the little ones with a Phillips and a standard, worked fine the first time, but the other side gave me a bit of grief
(if you click this stuff, you will see pictures of this stuff)
2001 Indian Scout
2011 KTM 250SX
1986 ATC250R
1989 Thunderbird SuperCoupe
2006 F150 Crew
