Results 1 to 2 of 2
Thread: cuyuna 440 question
    Jun 2009
    mishawaka
    4
    cuyuna 440 question
    im in the process of transplanting a cuyuna 440 out of a 78 scorpion sting, into a go kart. when in the sled the fuel pump has one line in from tank, one out to carb, and one that goes into one side of the crankcase. my question is if i mount tank above engine and have only one line from tank to carb and have it gravity fed. will i burn up the engine without having the line going to crankcase? or is that just for vacuum?
    Yamatrike400's Avatar
    Yamatrike400 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    MINNESOTA
    393
    Just plug the nipple on the case and you'll be fine.
