Results 1 to 13 of 13
Thread: 1986 YFM 225 carb help
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    I have a 1986 Yamaha YFM 225. I took the carb off today to clean it, got it clean and put it back together. the air/fuel mixture is 2 1/2 turns out. the throttle needle is on the middle clip. It will start easily, idles smooth and it will rev smooth until I put it into gear. when I put it into gear and give it gas it falls on its face. what could be the problem guys?
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    397
    ok guys, I moved the throttle needle from the 3rd or middle clip to the fourth clip on the needle. it runs alot better. it will idle smooth and rev smooth while in neutral. when in gear it will only run with the choke on 1/2 way. with the choke on 1/2 way, it will run good and is responsive to the throttle, but does not idle very well with the choke on. when I took the jets out of the carb, I ran a piece of wire through the little holes that go across the jets, but when I tried to run the piece of wire through the hole that goes length wise through the jet, the wire will go in, but not all the way through. shouldn't the wire go all the way through the jet length wise?? help me out here guys.
    Jordan
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Monroe MI
    5,787
    Yes, it should go all the way through. It tapers down, I burned the paper off a garbage bag tie and (very carefully) used the wire from that and carb cleaner. Probably not the best way to do it, but I had it soaking for days and it was still clogged. It was packed solid with green gook.
    FWIW, my book say fourth groove from the top for the clip and 1 - 1/4 to 2 - 1/4 turns out for the idle mixture screw.
    397
    MonroeMike, thanks for the help. I have been trying to get this atv running for a year. I will take the carb apart tomorrow and let it along with the jets soak for a couple of days. I have a gallon of carb cleaner that it can soak in. I have heard that if left for too long, the carb cleaner will eat the carb up, is this true?
    Thanks
    Jordan
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    397
    do you have a downloadable copy of that book? Or do you know where I can get one? If I have to go buy one, what is the best to get? I have a clymer manual for my atc 110 that doesnt seem very detailed.
    Thanks
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Monroe MI
    5,787
    I just had the jet sitting in the carb cleaner, not the whole thing. I cleaned the body with a toothbrush. I know Evaporust is safe to soak carbs in, but I never tried it. Not sure about the cleaner you have.
    I just have the quick data for the YFM225, no manual. When I get a chance, I'll scan it.
    397
    thanks, I appreciate it.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    397
    ok. I got it to run a lot better now. but I think there is something wrong with the float. It will idle for about two mins and then slowly idle down until it dies. It will start right back up, and will not idle too well until I open the carb drain bowl screw to let some of the gas out of the carb while idling and it will idle all day. I think the float height is set wrong. are they even adjustable? If not I will have to get a new float from the dealer. Is there anyone that would happen to have a yfm225 carb laying around?? thanks
    Jordan
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Monroe MI
    5,787
    Did you put the floats in with the round sides up?
    I doubt if the floats are bad, you can try them in a bucket of gas though. Mine aren't hollow on my 225, they are that black solid stuff.
    Set the float assembly on a flat suface, make sure both the floats are even, carefully bend them if they are not.
    Adjust your float the way described in this post.
    http://www.3wheelerworldforums.com/s...73&postcount=4
    397
    that sounds easy. I will have to wait until it quits raining here to do anything else to the atv. it has been raining for the last two days on and off and has dumped atleast 1" during each rainfall.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    397
    I got it to run nearly great now. it will rev smoth idle smooth until the carb loads up on it. If I keep the idle on the high side it idles good. It has some hesitation/missing a little bit. If I tunr the choke on like a 1/4 It runs excellent, so what do you think it might be? a jet still clogged? choke needs adjusting? how do you adjust the choke? bad float maybe? I would like to rebuild the carb but they do not make a rebuild kit for this carb. I know If it had new jets and a float in it, I could probably get the carb right, but I will have to wait if thats the case because money it tight right now.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Monroe MI
    5,787
    397
    mike, I appreciate it man. I will take another stab at it this weekend after, I help put an old suzuki quadrunner 250 4x4 together. it shouldnt take long though, just a top end.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
