Thread: 1985 250sx throttle/carb problems
    Charleston,Sc
    29
    First off hello i am new to the forum, this is my third trike, a 1985 250SX it idles excellent nice and quiet but soon as i apply throttle the engine loads up, i changed the NGK plug that came with the trike, i started the bike let it warm up it still loaded up but the odd thing is that reverse gear does not load up i can wind the engine out in reverse soon as i catch a forward moving gear it loads up i feather the throttle until i can get it up to speed and it runs fine but soon as i pin the throttle it begins to cough and load up until i back it off to about 75%. im not sure if it matters but first gear is trashed it kicks and jumps so i use 2-5 it starts fine, idles fine just have to feather the throttle, possibly old gas it came with 3/4 tank i topped it off with fresh 89 and put some SeaFoam that helped my dirt bike out a 2005 CR450F that sat for a year im open to any experienced mech's suggestions possibly just yank the carb and do a thorough cleaning?
    Apr 2009
    Parker, CO
    607
    What do you mean by load up?
    Oct 2007
    Minneapolis mn
    4,067
    if its like my BR carb (which it is) the float, and needle where way out of spec... Cant get a new float anymore, but you can have a beer and shim it with the aluminum can... (if its out of spec, I will explain later)
    Charleston,Sc
    29
    By loading up i mean coughing and sputtering acting like the engine is getting to much gas and choking out when i apply throttle it slows down then finally with feathering the throttle will get up to speed but never will allow 100% throttle to wind up the rpm's it has me puzzled as Ive never had to work on my previous trikes a Honda 200s (stolen) Yamaha 200 i sold, both ran great i miss my 200s topped out on asphalt at 60mph but i did confirm a purchase of 2 200x's one running one needs a head for a cool $500, the one that needs the head the owner tells me the previous owner shaved it too much and it made a tapping sound he shut off the trike and never ran it again
