Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: spark plug chop
    Jun 2004
    Oregon
    1,784
    Quote Originally Posted by crzyd247 View Post
    hey man i am learning alot from what you saying thank you so much i am in chicago so not sure what alltiude i am iin i am about to ride it tomorrow i just cleaned that carb again set air screw to stock spec i am 40 to 1 gas new plug new airfilter the only think i didnt and dont know how to check is my float i have manual but kinda unsure how to check them . and now that you say i will try to find the ground on the bike and clean and make sure thats getting good conection i am guessing its right by the coil thanks for all the help
    Still would like to know what altitude youre riding at man.. Never been to chicago so i have no idea what its like over there...But i know it can snow alot so im guessing you could be up high somewhat..
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Apr 2009
    Parker, CO
    607
    Read the jetting thread in world class help. Its packed full of great information.
    Jun 2004
    Oregon
    1,784
    Anyluck crzy? Kinda wondering how its running now
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    boosted96cobra's Avatar
    boosted96cobra is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    n utah
    279
    Reading the plug doesn't mean you have to cut it off. That how to is very mis informed! Why? Because you never want to full throttle through all the gears if the jetting is off, especially lean, that is just asking for trouble.
    My bike runs in the 155 range, 60 pilot (39mm carb. not stock) but I have 150-168 range of jets. Altitude, tempature, ect ect all can have an effect on jetting. Last trip out I was running a 152 during the day, went as high as a 158 when it was colder at night.
    I have noticed I can run on the same clip on the needle and the same pilot. But if I were you I would be glad your jetting is off so you can learn to do it. When you have the pilot and needle set, changing the main is simple, just loosen the clamps that hold the rubber on both sides of the carb, turn it so you can get under the bowl, remove the 17mm float bowl, and use a 6mm to remove and install the new main jet. It's that easy.
    http://i291.photobucket.com/albums/ll292/sagep11/IMAG0069-1.jpg
    84 tri-zinger
    85 ATC 250r
    86 TRX 250r
    85 ATC 350x
    86 ATC 200x
