Thread: 250r leaky base gasket- need help
    Sep 2008
    Wisconsin
    68
    hey everyone i just got a 81 250 r and i noticed the oil leaks out where the jug goes onto the crank case on the left side. so i was thinking the base gasket was bad. how important is it that i change this and how soon should i do it? and should i not drive it until i fix it??
    May 2007
    Coshocton, Ohio
    1,815
    Quote Originally Posted by ToddFrydrych View Post
    Todd if the base gasket is leaking it is critical that it is fixed before you ride it.
    Are you sure that the oil isn't coming from the exhaust flange and running down the cylinder and laying on the top of the case in that area?
    If the base gasket is leaking and oil is present there that means that air can be entering the cylinder there also. That would create a lean condition which could lead to catastrophic failure of the engine.
    You might try to check the torque of the base nuts. If they aren't tight enough you can be sure that, that is the problem. The best way to check for leaks is to do a leakdown test.
    Appalachian American Racing
    the home of
    Sep 2008
    Wisconsin
    68
    no its leaking from the base gasket. and i checked the bolts and there tight. and since i gotta change it where can i get the top end gaskets? and do i have to pull the motor or can i do it while its in frame?
    Southern MN
    1,875
    You can get the base gasket from honda, but it would be spendy. I would replace all the top end gaskets, as you arent supposed to re-use the head gasket anyways, especially if its who knows how old. The head and jug can be removed in the frame, but it is easier to work on the motor on a bench if you ask me, but its your call. One place you can get a top end gasket kit would be at denniskirk.com ,, I usually have good luck with them. Otherwise, you can check ebay, or a local cycle shop in your area should be able to order it for you. Good Luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
